Re: Mopar Mega Block [Re: swiz69] #1037107
10/01/13 08:24 PM
10/01/13 08:24 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I know this thread has been going for awhile, but I just picked up a wedge 4.5bore with the exact markings mentioned here...my question is: did they change lifter bore angles in the "MC" blocks or are they 45° stock angle?
They should be stock unless it was a block without the bores bored for use in AH super stock where they drilled the holes at the angle they wanted.
Is it a hemi or wedge block ?
Re: Mopar Mega Block [Re: JohnRR] #1037108
10/01/13 08:55 PM
10/01/13 08:55 PM
ohio, usa
swiz69 Offline
swiz69  Offline
ohio, usa
Its a wedge block...identical #'s and markings to the one pictured in earlier post...my concern was only brought about because Crane Cams website states some blocks had 47° and sometimes 48 or 50 (in raised-cam blocks) which would cause 1/2 of the motor to have inaccurate cam timing...mine is standard cam location block, so I should be OK?
