Re: Superbird Overheats
[Re: roadrunner69s]
#1037035
07/22/11 06:38 PM
07/22/11 06:38 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
Good to hear things are improving. Don't leave that straight hose water in the system for too long. Replace it with demineralized water at some point to minimize chemical deposition. You don't want a nice fresh core getting caked up with carbonates. I used to work at a place that had large demin tanks so bringing home a 5 gallon jog of Demin water whenever it was needed was a snap. Maybe you know a friend who works at a company that purifies the incoming city/well water (power plants, boiler houses, waste to energy plants, etc.)
RR69s
Wouldn't "distilled water" be the same or good to use? You can get distilled water in just about any grocery store or pharmacy, etc,. We used only distilled water (no coolant) in our water cooled motorcycle engines that had magnesium engine cases and water pumps since the early '80's and never had a problem.
MikeR
[Re: DAYCLONA]
#1037039
07/23/11 10:54 AM
07/23/11 10:54 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Ask Dr. MoPAr for a pERcrIpTIon for some ZEREX G-05 and REDLINE water wetter.....your bird will feel better after a dose
Mike, you have me convinced............ I'll go get some G05 to add to my distilled water and water wetter I already have...... My have to recharge the water wetter since I'll be draining some of the water inlew of the "G".......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Bayou_Bird]
#1037040
07/23/11 02:33 PM
07/23/11 02:33 PM
Posts: 4,179 California
mickm
California
Hello Mike, I can't believe it but I drained the radiator and added plain hose water.
now drain it all and replace it with anti-freeze and distilled water.
i know some people argue this point, but every radiator guy i know insists on it, as well as all the engine builders i can think of. the minerals in tap water will eventually cause build-up and corrosion.
why take the chance?
