Re: big block VS small block
[Re: Mr.Yuck]
#1035555
07/21/11 06:09 PM
07/21/11 06:09 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
Pretty hard to build a 440 with only 500 HP. We would have to go to the junk yard for a set of 906 heads.
But yet i have probably seen more high 11 second big block Mopar "race cars" at the track than anything else, then when you look under the hoods they look like they should run 9.50's.
The above wouldnt be so bad if it wasnt 100% true ![](/ubbthreads/images/graemlins/tsk.gif)
Almost as bad as the proverbial huge inch 67-69 Camaro's you see all the time that only seem to run 10.50's and are all cut up to heck so they will even run that good ![](/ubbthreads/images/graemlins/biggrin.gif)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: earthmover]
#1035557
07/21/11 06:18 PM
07/21/11 06:18 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
i got it
nah don't lock it. I don't think anybody here has taken anything personally. It's all good fun.
[Re: vttm]
#1035559
07/21/11 07:00 PM
07/21/11 07:00 PM
Posts: 320 PA
w7smallblock
PA
So using some of you guy's theory any engine 500 hp no matter what the torque "say one is 500 the other 700" they will run the same if every other aspect of the combination is optimized? not trying to argue just trying to understand.
Yes this is right torque is equallized through the rear gear. Say 3.91 for the big block and 4.88 for small block (as an example)
[Re: HYPER8oSoNic]
#1035562
07/21/11 07:10 PM
07/21/11 07:10 PM
Posts: 3,695 nc
emarine01
nc
![](/ubbthreads/images/graemlins/shruggy.gif)
They BOTH have to make 500 HP AND weigh 3000 lbs.
Looks like the original poster isn't going to settle any argument and started one here.
I'm going to throw a cow chip in this thread and leave it alone, before !! How come so many GOOD POINTS were produced in THIS thread, and not too many on the "383 vs. 440" thread? Hmm, basically the concept is the SAME, with the EXCEPTION of the vehicle weight.
Humm...... Cow Chip..... ..... How high do you turn your cow ....... .......
As high as it can go, without it letting loose all over you.
Ya ask a simple question and seems that cows just want to crap all over ya This post needs a little injection of bad humor every now & then ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: S/ST 3040]
#1035565
07/21/11 08:46 PM
07/21/11 08:46 PM
Posts: 781 MD
HEMI472
MD
i am glad i read this now i am going to tear out my 488 inch v-10 and put in a stock 340 they both make around 300 hp so there will be no difference. i am liking the small blocks ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: HEMI472]
#1035566
07/21/11 09:02 PM
07/21/11 09:02 PM
Posts: 188 MD.
vttm
MD.
Not a bad idea. Come to think of it I wasted the money on my cummins should have just got the 360 same hp, just a gear change from same performance. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: moparmanjames]
#1035567
07/21/11 09:04 PM
07/21/11 09:04 PM
Posts: 320 PA
w7smallblock
PA
It's not a Mopar comparison but it is somewhat relevent to the arguement. I think it was Hot Rod a few years back that built two engines, a small block 406 and a big block 406, same cam profile. I cant remember the Dyno numbers but the big block heads flowed better so it kicked butt on the small block. They both went in the same Chevelle with the weight the only difference, the smallblock managed 12.50's I think and the big block ran 12.30's or 12.20's, even with the weight disadvantage and the same cubes.
The only reason the big block won was because the gear and converter favored it. You cant use the same gear and converter becuase the big block made more torque.
472HEMI you might as well pull the v-10 and put in a 340 because when you don't get the truck out of the garage it doesn't really matter. They both will rust away to nothing at the same rate.
[Re: HEMI472]
#1035568
07/21/11 09:05 PM
07/21/11 09:05 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
just get the 358 ci nascar motor there going for about 6 g's..and they only make 850hp ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: quick77rt ]
#1035571
07/21/11 10:05 PM
07/21/11 10:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Which one will last longer at the 500hp level? My vote goes to the BB.
Mopar to the bone!!!
[Re: w7smallblock]
#1035572
07/21/11 11:10 PM
07/21/11 11:10 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Your Whole argument is correct on paper.
But it isnt in reality. The 500 Hp SB power curve will be smaller then the BB.
Unless both combos are pegged at the start to finish at 500 HP, witch they wont be. The BB with the wider torque/hp curve will be the winner.
Your argument is a theoretical math/physics argument on paper , not a reality argument.
500 + 500 = 1000 on paper. ![](/ubbthreads/images/graemlins/thumbs.gif)
500 hp BB and 500 hp SB doesnt = the same ET with different torque curves!
Further, in reguards to HP, math and physics being so precise.
Why is it that every stinking website for mph vs weight = xxx amount of HP is so far off from one another by 100 HP or so. ![](/ubbthreads/images/graemlins/devil.gif)
HP is a Calculated number based off of RPM. Both Torque and HP are for real. Torque can be measured, but HP is calculated.
And it can be calculated pretty accurately, But not on a vehical that races down a track with a variable Torque Band width.
For the arguments sake Im on the side of the BB is the winner in this same 500HP senario. Because in reality, the two combos will never be fully optimized to the 500HP ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Sport440]
#1035573
07/21/11 11:35 PM
07/21/11 11:35 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I was just wondering what made the fastest pass at the heads up shoot out they just had on here. Was it a small block or big block?
Brett Miller W9 cnc'd heads STR Chassis fabraction
