Re: big block VS small block
[Re: w7smallblock]
#1035496
07/20/11 08:38 AM
07/20/11 08:38 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
I agree 5oo hp is 5oo hp. But my opinion is, that if both cars are same hp, at same weight, and properly geared with all the right parts in all the right places, they should be very close the same ET. Because the small block will have a more aggressive cam and wider rpm ramge to make 5oo hp, and also use a steeper converter. But because of the wider torque range, the big block "should" 60 ft better, and the small block "should" mph better, so I think it will equal out. My Quote:
Oh by the way my car can beat your car and I could beat you at arm wrestling and my dad can beat up your dad.
1. I'll race ya! spot me to the 60 ft, my car is heavier with the trans hanging in it, 2. I'll arm wrestle you! spot me 45* and let me use two arms, 3. My Dads car has a WEDGE with a TORQUEFLITE, what's your Dads got?
later Buddy and btw, who is arguing with you?
It's a bigblock with a torque flight!!!
[Re: w7smallblock]
#1035497
07/20/11 09:18 AM
07/20/11 09:18 AM
Posts: 2,027 Trumbull,CT.
jim sciortino
Trumbull,CT.
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). Do you agree the 440 will make more torque given the larger stroke? Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET? If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thoughts please.
I'll take the engine that makes the 500hp at the higher rpm and hangs on better after peak.
I will gear and converter that engine accordingly and take my chances. You can keep the low rpm torque.
[Re: S/ST 3040]
#1035499
07/20/11 11:36 AM
07/20/11 11:36 AM
Posts: 5,080 organ
maximum entropy
organ
if they are the same weight (which i don't think was mentioned by the op), they'll run real close. real close.
[Re: maximum entropy]
#1035501
07/20/11 04:00 PM
07/20/11 04:00 PM
Posts: 2,864 IN
Irun5snd8th
IN
Perhaps we should take a look at the guys that are wringing every little bit out of the stock combos. Stock eliminator. Who is the fastest 340 or 360 in stock eliminator? Who is the fastest big block (non factory racecar) running in stock eliminator? I honestly dont know but it would be a decent indicator. Especially since the big block cars SHOULD weigh more. Just a thought.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: HYPER8oSoNic]
#1035505
07/20/11 07:11 PM
07/20/11 07:11 PM
Posts: 3,695 nc
emarine01
nc
They BOTH have to make 500 HP AND weigh 3000 lbs.
Looks like the original poster isn't going to settle any argument and started one here.
I'm going to throw a cow chip in this thread and leave it alone, before !! How come so many GOOD POINTS were produced in THIS thread, and not too many on the "383 vs. 440" thread? Hmm, basically the concept is the SAME, with the EXCEPTION of the vehicle weight.
Humm...... Cow Chip..... ..... How high do you turn your cow ....... .......
[Re: w7smallblock]
#1035506
07/20/11 07:30 PM
07/20/11 07:30 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I agree with Chris's barracuda horse power is horse power which is derived from torque on a dyno. So 500hp runs the same in a 3000lb car no matter what CI it is. :
Technically this is correct, The Dyno doesnt know the CI size of the motor while measuring the torque to get the Calculated 500 HP.
Both torque readings will be variably different and at different RPMs to get the 500 HP.
These cars arent raced down the track @ exactly 500 HP. They usually run in a rpm band with of about 1000 to 1500 Its in that dwell time that the 500 HP BB will have the advantage over the 500 HP SB
As the SB will have a more Peaky powerband vs the BB broader powerband. The longer stroke of the BB will have more torque then the SB,
So IMO, even though Both motors will produce 500HP, its the power under the curve in the combos powerband thats going to have more effect on ET then just the Peak 500HP
Now you might argue that if Both cars are run down the track with verts Right at their HP peaks,start to finsh, the BB say at 6250 rpm and the SB at 6850 rpm. Then would they be Equal?
Technically , they should be, but lets not forget the 500HP is still a Calculated number based off of two different RPMs
The reality of the comparison on paper looks good, but the reality of the track is different.IMO
It would be a fun test though, but in reality could we really trust the calculated numbers to be accurate. Heck around here we have dynos that are 100 HP off from one another sometimes.
[Re: w7smallblock]
#1035510
07/21/11 12:55 AM
07/21/11 12:55 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I guess this will never be settled so my argument with my buddies will just go on. But it dosen't matter he knows deep down inside that he's wrong and I'm right
If you take a car with a 500 hp 360 and take it to the track it'll run a number. Now, if you take that same car, pull the 360, stuff a 500 hp 440 in it and take it back to the track (traction not being an issue), it will go faster. I had a 408" (I know that's not a 360) small block, 11.2:1 cr, 270 cfm eddie heads, torker II intake, cam was 231/237, .560 lift on a 108. Based on others' builds, I would say it was pushing 475-485 hp. The cheap POS eagle cast crank broke after 6000 miles (rated to 500 hp and 7000 rpm!!) ((my own fault, shoulda known better)) so I built a 440. Stock crank, stock rods, KB flat tops, ported 452 heads that were also in the 270 range on the intakes. Don't know what the compression is (don't care, it runs on pump 87 at 5500 ft) 228/236 cam (TQ50), less lift 110 lobe sep. Torker II intake and I dynoed this one. 485 hp, 507 tq. Everything else was the same. Truck is faster with the BB. Same 750 carb as well. 440 needs more timing, sounds pretty good, 408 had a wicked exhaust note with that compression and a little more overlap. My point being, car being the same, the 440 will start pulling harder, sooner due to the extra cubic inches, no so much because of the longer stroke, which is only .160" longer. Start changing the car to favor each specific engine and the results may be different.
[Re: dodgeboy11]
#1035511
07/21/11 01:08 AM
07/21/11 01:08 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Which one weighs more.. A: 1 pound of Lead... B: 1 pound of feathers... Maybe that will help.. Has nothing to do with "Big or Small" blocks.. Chris...
[Re: Chris'sBarracuda]
#1035512
07/21/11 01:26 AM
07/21/11 01:26 AM
Sport440
Canton, Ohio
Chris...
Heres my comparison analogy
Witch one hits the ground first.., from a 1320' drop!
A: 1 pound of lead..
Mike
[Re: Sport440]
#1035513
07/21/11 01:29 AM
07/21/11 01:29 AM
dodgeboy11
Las Vegas, NV
Chris...
Mike
WELL, if the pound of feathers is in the shape of a parachute...
#1035514
07/21/11 01:31 AM
07/21/11 01:31 AM
Posts: 320 PA
w7smallblock
PA
You need to go back and reread my post it says 500hp each with converter and gears to match the motors rpm range. You put a 440 where you had a 408. You also said you never dynoed the 408 but did the 440 so this tells me you got everything out of the 440 being dyno tuned and the 408 was not to it's full potential. Correct me if my statement is not true.
