Re: big block VS small block
[Re: fishy340]
#1035455
07/19/11 05:59 PM
07/19/11 05:59 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
360 block,i'd go with 340 better and stronger..but any way i've posted this a few times,,4" crank,40 over bore,eddie heads not even touched,750 hp carb,4.30 gear 29" tire w a 3500 stall treemaster conv..motor made 504hp at 5800rpm and 546lb'S OF torque 418ci went 10.80's in a 3200 dart sport..cam was flat tapped bullit made it 255/255 @ 50 588 lift
Your math is out a bit. 418 does not = 360.
[Re: Mr.Yuck]
#1035456
07/19/11 06:01 PM
07/19/11 06:01 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You guys are debateing about nothing that this thread has to do with just The fact is 500 hp IS 500 hp weather it is a BB or SB if the car is tuned to hook perfect and keep the engine in it's own power band one will not be faster than the other. The SB will make less TQ but will end up with a lower gear ratio and TQ at the wheel will be the same. As for you guys and your peeing match, 500 hp is easy with either combo and costs about the same with either. A 1/2 decent port job on a X head or a 906 and similar priced cam intake headers carb... will make 500 hp. Machine work is the same and every component is going to be almost the same $$$. The SB will naturally turn more RPM to make the same HP but so what, matched with a 904 instead of a 727 the SB combo is going to be nearly 200lbs lighter. A 4 cylinder civic can make NA 500 hp and no TQ, they will just run super low gear ratios and turn the 500 hp into the same TQ as a 440 at the tires and the bottom line(the bottom of the tire) is what matters, it can still run as fast in a 3000# car but it just needs more gear to get the same TQ at the tire... of course a 500 hp honda is VERY much more expensive.
[Re: RemCharger]
#1035457
07/19/11 06:09 PM
07/19/11 06:09 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
He said that he would go with a 340....340,.040 = 418"!!!!!
[Re: MIKES_DUSTER]
#1035458
07/19/11 06:19 PM
07/19/11 06:19 PM
RemCharger
Sk. Canada
whats a 40 over 340?.. 345? Mike you forgot the 4" crank that was never installed at the factory. 4" crank = not stock anymore.
[Re: w7smallblock]
#1035459
07/19/11 07:04 PM
07/19/11 07:04 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Question one-yes Question two- yes question three - maybe? For number three, it is all about the most efficient way to get the most average hp to the track the full length of it. Odds are the small block will have a narrower power band than the BB, and will have more flash and stall. So, it kinda doesn't matter. You build the converter and pick the gear ratios to make the power band you have work. When you say both making 500 hp, I assume you also mean they will average the same hp over a wide enough range so that they will be competitive.
[Re: gregsdart]
#1035462
07/19/11 07:42 PM
07/19/11 07:42 PM
Posts: 781 MD
HEMI472
MD
so we now have 2 pages and 2 answers. so you all are say put steep gears in the small block to make up the difference in torque.but if you put all that gear in it to make up torque is it going to make it to the finish line in its power range?? to much gear and its going to slow down
[Re: w7smallblock]
#1035464
07/19/11 08:55 PM
07/19/11 08:55 PM
Posts: 5,080 organ
maximum entropy
organ
500 hp is 500 hp. if both cars are optimized, the small block car will go faster (less weight). the two engines will have different torque curves, because it will take a bigger and/or better head and cam for the 360 to make that number, not because of shorter stroke. torque is a factor of cubic inches more than anything else. the 360 won't need to make (and won't make) as much torque to make 500 hp, because it will be higher up in the rpm range. the cars being optimized will level the playing field. that's where the weight advantage will win the game for the small block, imo.
[Re: maximum entropy]
#1035466
07/19/11 09:15 PM
07/19/11 09:15 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
they weigh the same
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1035467
07/19/11 09:18 PM
07/19/11 09:18 PM
Posts: 781 MD
HEMI472
MD
they weight the same?????
[Re: sixpackgut]
#1035468
07/19/11 09:19 PM
07/19/11 09:19 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
they weigh the same
I was going to say that, but was wondering if he ment reciprocating weight
[Re: viperblue72]
#1035473
07/19/11 09:45 PM
07/19/11 09:45 PM
I will just say big block.
