Re: Burnout Style/Technique Question
[Re: JERICOGTX]
#1034281
07/18/11 05:29 PM
07/18/11 05:29 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Tim Hyatt, can reface the clutch discs for you. Do NOT throw them out.
Thanks Jeff. Yep, Tim did reface the clutch disks (have 2 spares), its the flywheel and pressure plate facings that are toast. I like to look at them every now & then. This year I went back to an all steel flywheel and pressure ring.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: JERICOGTX]
#1034283
07/18/11 08:22 PM
07/18/11 08:22 PM
oldiron
New Hampshire, USA
Yep, back to running the vert. Last year I was running a 68 barracuda w/same drive train, but then I took it to a body guy in January who said it would be finished by march. I guess that I thought he meant 2011
[Re: oldiron]
#1034286
07/18/11 09:36 PM
07/18/11 09:36 PM
Posts: 10,091 MN
JERICOGTX
MN
Well if a body guy tells you it will be done in a certain month, you need to ask what year. LOL. Post pics of the Barracuda when it gets out of body shop jail.
[Re: mloboda]
#1034287
07/18/11 09:39 PM
07/18/11 09:39 PM
Posts: 10,091 MN
JERICOGTX
MN
Next year a 298" W7 head motor and 5 speed go in. Life begins at 10,000 RPM !!!
Your only going to run 5/8 of a engine? Life must begin when valve springs die.
