Re: W7, 8, and 9 Intake Manifolds
[Re: Plumb Wired]
#1034211
07/19/11 10:31 AM
07/19/11 10:31 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
420 ported by Matt Hensley, Applied Nitrous Technologies fogger, 4150 to 4500 adapter blended
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: MR_P_BODY]
#1034214
07/19/11 08:02 PM
07/19/11 08:02 PM
Posts: 3,695 nc
emarine01
nc
Heres a pic of one of the first 598s that was rough cast that I machined to fit a 4500 and doing the port work... its done now but I still havent run it yet to make sure of the port balance using EGTs
Man Mike... Did you split another one or is that the same one from a wile back
[Re: emarine01]
#1034215
07/19/11 08:16 PM
07/19/11 08:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Same one... that was the last of my W manifolds... that one and my 420 is all I own
[Re: MR_P_BODY]
#1034216
07/19/11 08:49 PM
07/19/11 08:49 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Lots of great pics. Thanks all! Wonder about all the hrs to finish one. Saw another Wilson int a while back, just beautiful pcs.
[Re: theclutcher]
#1034217
07/19/11 10:02 PM
07/19/11 10:02 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
so which intake works better?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: MR_P_BODY]
#1034219
07/19/11 11:11 PM
07/19/11 11:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Seems to be a lot of material left in the intakes pictured.
My 420 does not have much work. I was told by the big NA guys I would be down 50 HP due to how much material is still in my 420. My plenum is quite a bit larger than the ones pictured. The runners are basically as cast with the exception of port matching and blending well up the runners.
It's too hot and I am too lazy to take some pics. Probably should sense they are for sale. But, someone will copy my unskilled work. LOL The 598 I have was done by a local professional and looks really nice in the plenum but runs abouts the same as the others. At least one would not have to weld over any overcuts.
Leon
[Re: MR_P_BODY]
#1034221
07/20/11 01:21 AM
07/20/11 01:21 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Where are the differences? Divider length thickness or plenum vol? On the fence as to using a carb adapter for dominator or carving intake. With adapter, can at least go back to smaller carb if needed. Also like idea of splitting the manifold, cant recall who does that.
[Re: theclutcher]
#1034222
07/20/11 09:23 AM
07/20/11 09:23 AM
MR_P_BODY
Just looking down the plenum its different... I think its the dividers... I'll have to look later today
[Re: S/ST 3040]
#1034225
07/20/11 09:29 PM
07/20/11 09:29 PM
Posts: 3,396 Pa
Hot 340
Pa
That was the revision.
I know the AB was a revision, but exactly what changed? Is there a story there?
