Page 3 of 3 1 2 3
Re: W7, 8, and 9 Intake Manifolds [Re: S/ST 3040] #1034230
07/23/11 03:17 PM
07/23/11 03:17 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Last one.
Thanks for the pics guys.
Re: W7, 8, and 9 Intake Manifolds [Re: Hot 340] #1034231
11/23/11 07:57 PM
11/23/11 07:57 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Gonna bring this one back up. . when machining the top from a 4150 to a dominator flange does the "cloverleaf" style opening work better than the plain, square dominator sized opening?
Re: W7, 8, and 9 Intake Manifolds [Re: Hot 340] #1034232
11/23/11 10:42 PM
11/23/11 10:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think it is different depending on the intake. Like a 772 is cloverleaf as a 420 would be square. Don't know for sure.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: W7, 8, and 9 Intake Manifolds [Re: 1967dartgt] #1034233
11/24/11 10:44 AM
11/24/11 10:44 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
UNC OUgh
The version you go with depends on what you prefer with your combo. Some intakes have less meat to mill out and end up very narrow on the sealing surface. My 772 is very thin with an open plenum. But, 468 CID with a good dose on a plate system will not want a cloverleaf. If the thin gasket area scares you one can always build the outer flange up with alluminum. I had no issues and was faced with a no external welding rule in the class. I tried cloverleafs but did not like with my combos.
Re: W7, 8, and 9 Intake Manifolds [Re: Leon441] #1034234
11/25/11 11:16 PM
11/25/11 11:16 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
UNC OUgh
Thanks fellas..So what exactly does the cloverleaf do? Is it better for smaller cube combos?
Re: W7, 8, and 9 Intake Manifolds [Re: Hot 340] #1034235
11/26/11 11:28 PM
11/26/11 11:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I'm reaching here but a couple things come to mind. The plenum would be a little smaller. You would boost signal to the carb sort of like the trick spacers. Personally I had to run a large spacer so the cloverleaf was pointless.
Leon
Re: W7, 8, and 9 Intake Manifolds [Re: Leon441] #1034236
12/13/11 06:38 PM
12/13/11 06:38 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
What's the cost on the Ritter made intake? Is there a big difference in the 772 intake vs the 420?
Page 3 of 3 1 2 3
