Re: W7, 8, and 9 Intake Manifolds
[Re: Hot 340]
#1034191
07/17/11 02:42 PM
07/17/11 02:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the 420 that I milled to fit a 1050 dom... I havent looked at the other but I would assume the plenum size is different as well as the deck heights
[Re: MR_P_BODY]
#1034192
07/17/11 08:12 PM
07/17/11 08:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
772 is for a tall deck. I have one but it was mistakenly milled wrong and when it got corrected guess what. It now fits a short deck block.
I also have a 598 and a 420. The 420 is the baddest of them all as you can make it much larger inside.
Leon
[Re: Hot 340]
#1034194
07/18/11 09:39 AM
07/18/11 09:39 AM
MR_P_BODY
Thanks guys. So were some designed for nascar and others for drag racing? The overall design looks to be the same.
I believe the 420 was for nascar... its only made for a 4150 carb
[Re: W5DART66]
#1034197
07/18/11 03:11 PM
07/18/11 03:11 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would like to see pics of these intakes. i have an obsession
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: W5DART66]
#1034198
07/18/11 04:05 PM
07/18/11 04:05 PM
Posts: 624 Baltimore,MD
lowbudget
mopar addict
mopar addict
Baltimore,MD
"420" was dragrace only as NASCRAP did not like the way the "420" looked so it was never run in the trucks. "598" and "598AB" was the nascar intake.
Interesting, never heard that before and thanks for the info
[Re: sixpackgut]
#1034199
07/19/11 12:13 AM
07/19/11 12:13 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Here is a 420... repro from Kent Ritter.
[Re: S/ST 3040]
#1034206
07/19/11 08:18 AM
07/19/11 08:18 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Hey Vic! That sure saves a lot of carving... any pics how you finished that one?
[Re: Hot 340]
#1034208
07/19/11 10:03 AM
07/19/11 10:03 AM
MR_P_BODY
Heres a pic of one of the first 598s that was rough cast that I machined to fit a 4500 and doing the port work... its done now but I still havent run it yet to make sure of the port balance using EGTs
[Re: Plumb Wired]
#1034211
07/19/11 10:31 AM
07/19/11 10:31 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
420 ported by Matt Hensley, Applied Nitrous Technologies fogger, 4150 to 4500 adapter blended
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: MR_P_BODY]
#1034214
07/19/11 08:02 PM
07/19/11 08:02 PM
Posts: 3,695 nc
emarine01
nc
Man Mike... Did you split another one or is that the same one from a wile back
[Re: emarine01]
#1034215
07/19/11 08:16 PM
07/19/11 08:16 PM
MR_P_BODY
Same one... that was the last of my W manifolds... that one and my 420 is all I own
[Re: MR_P_BODY]
#1034216
07/19/11 08:49 PM
07/19/11 08:49 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Lots of great pics. Thanks all! Wonder about all the hrs to finish one. Saw another Wilson int a while back, just beautiful pcs.
[Re: theclutcher]
#1034217
07/19/11 10:02 PM
07/19/11 10:02 PM
sixpackgut
Charleston
so which intake works better?
[Re: MR_P_BODY]
#1034219
07/19/11 11:11 PM
07/19/11 11:11 PM
Leon441
Lynchburg, VA
Seems to be a lot of material left in the intakes pictured.
My 420 does not have much work. I was told by the big NA guys I would be down 50 HP due to how much material is still in my 420. My plenum is quite a bit larger than the ones pictured. The runners are basically as cast with the exception of port matching and blending well up the runners.
It's too hot and I am too lazy to take some pics. Probably should sense they are for sale. But, someone will copy my unskilled work. LOL The 598 I have was done by a local professional and looks really nice in the plenum but runs abouts the same as the others. At least one would not have to weld over any overcuts.
Leon
[Re: MR_P_BODY]
#1034221
07/20/11 01:21 AM
07/20/11 01:21 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Where are the differences? Divider length thickness or plenum vol? On the fence as to using a carb adapter for dominator or carving intake. With adapter, can at least go back to smaller carb if needed. Also like idea of splitting the manifold, cant recall who does that.
[Re: theclutcher]
#1034222
07/20/11 09:23 AM
07/20/11 09:23 AM
MR_P_BODY
Just looking down the plenum its different... I think its the dividers... I'll have to look later today
[Re: S/ST 3040]
#1034225
07/20/11 09:29 PM
07/20/11 09:29 PM
Posts: 3,395 Pa
Hot 340
Pa
That was the revision.
I know the AB was a revision, but exactly what changed? Is there a story there?
[Re: S/ST 3040]
#1034230
07/23/11 03:17 PM
07/23/11 03:17 PM
Posts: 3,395 Pa
Hot 340
Pa
Last one.
Thanks for the pics guys.
[Re: Hot 340]
#1034232
11/23/11 10:42 PM
11/23/11 10:42 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I think it is different depending on the intake. Like a 772 is cloverleaf as a 420 would be square. Don't know for sure.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Leon441]
#1034234
11/25/11 11:16 PM
11/25/11 11:16 PM
Posts: 3,395 Pa
Hot 340
Pa
UNC OUgh
The version you go with depends on what you prefer with your combo. Some intakes have less meat to mill out and end up very narrow on the sealing surface. My 772 is very thin with an open plenum. But, 468 CID with a good dose on a plate system will not want a cloverleaf. If the thin gasket area scares you one can always build the outer flange up with alluminum. I had no issues and was faced with a no external welding rule in the class. I tried cloverleafs but did not like with my combos.
Thanks fellas..So what exactly does the cloverleaf do? Is it better for smaller cube combos?
[Re: Hot 340]
#1034235
11/26/11 11:28 PM
11/26/11 11:28 PM
Leon441
Lynchburg, VA
I'm reaching here but a couple things come to mind. The plenum would be a little smaller. You would boost signal to the carb sort of like the trick spacers. Personally I had to run a large spacer so the cloverleaf was pointless.
Leon
