Help: Six-Pack Fuel Lines #103313
08/11/08 05:46 PM
08/11/08 05:46 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hi All,
I was trying to fix a leaky Accelerator Pump on the center 2-bbl on a '70 440-6 setup. I purchased the new upper steel fuel lines already in anticipation of having problems with the existing fuel lines.
But, I am having all sorts of trouble now trying to get the existing lines off the carbs in order to remove them. I first tried loosening the lines for the front and rear at the fuel inlet on the carb. But the inlet adapters in the carb just turned with them. I can't possibly get another wrench in there to hold them still.
I next tried removing lines at the brass "T" blocks in the line -- but only one of them will budge. And in the process I twisted the line to the rear carb
Question #1 - Can I spray something like PB Blaster or Liquid Wrench on these fittings safely? I would generally never think of spraying stuff like this near the carb, but these things are totally stuck and no amount of force is getting them to move.
Finally, I tried putting the lines I had loosened up back in place to at least be able to move the car, but then it started leaking pretty heavily at both the front and rear carbs inlet (where I was trying to loosen early but it only spun on me). I still can't get them to move one way or the other at this point, but I must have done something to get them leaking like this.
Does anyone have any suggestions on what I can try next with this? This was my first attempt at carb removal ... a lot of lessons learned here I guess.
Thanks a lot for any ideas!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103314
08/11/08 06:13 PM
08/11/08 06:13 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
If you are replacing the lines anyway, cut them (large side cutters?) at the fuel line fitting, then use a 6 point deepwell socket to get the line fittng out of the carb fitting.
jt
Yeah, it's hopped up to over 160...
Re: Help: Six-Pack Fuel Lines [Re: jt4406] #103315
08/11/08 06:47 PM
08/11/08 06:47 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Ok, thanks.
Does anyone know whether it's ok to spray something like PB Blaster on the fuel line fittings to see if they might budge that way? Or will this stuff possibly be dangerous?
Thanks!
Re: Help: Six-Pack Fuel Lines [Re: jt4406] #103316
08/11/08 06:50 PM
08/11/08 06:50 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
To stop the inlet adapters from turning I had to wedge a large flat head screwdriver along the left side of it and the carb body.
Re: Help: Six-Pack Fuel Lines [Re: 500Stroker] #103317
08/11/08 08:09 PM
08/11/08 08:09 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Ok, thanks for the info on this. If I need to cut the steel fuel lines in some spots (in order to get the carbs off the motor), what is the best way to do this?
I don't see enough room to get a hacksaw in there. Is there another way to cut these fuel lines easily? Has anyone ever had to do this?
I sprayed down the nuts with PB Blaster but they still won't turn at all.
Thanks!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103318
08/11/08 08:45 PM
08/11/08 08:45 PM
E.Amherst, NY
69RR Offline
69RR  Offline
E.Amherst, NY
I would just let the inlets turn. then when they off
you can put a wench on them. I've had to that way. I've had 4 six pack cars and each was bit!h to take off.
Dean Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103319
08/11/08 08:55 PM
08/11/08 08:55 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
are you using a line wrench? those are made just for taking off soft brass fittings.
Re: Help: Six-Pack Fuel Lines [Re: 69RR] #103320
08/11/08 08:56 PM
08/11/08 08:56 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
I sprayed down the fitting nuts to the fuel blocks with PB Blaster, but I can't get them to budge at all. I don't know how they could have been put on there so tightly, but I just can't move them. Yes, was using a 1/2" flare wrench on this.
Also, when I tried to start up the car, I have a pretty good leak going at the carb fuel inlets now. I guess all the turning (of the fitting at the adapter) caused it to spring a leak... uggh...
I'm not sure what to do next on this... Can't unscrew the lines at the carb inlet or at the fuel block "T's". Has anyone had to resort to cutting the steel fuel lines to get the carbs off the car? If so, how did you do it? There isn't enough room for a hacksaw....
Thanks guys!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103321
08/11/08 11:14 PM
08/11/08 11:14 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hey Guys,
I did some searching on the web ... looks like there is a Mini Pipe Cutting device that might work for cutting my steel fuel lines at the carb?? (looks like it's also used for brake lines)
Has anyone used this to cut the steel fuel lines? I am not sure how thick or strong these lines are. Anyone done this before?
Thanks!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103322
08/12/08 12:35 AM
08/12/08 12:35 AM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Now you know why 4 bbl carbs became very popular with the early six pack owners. I built a rubber fuel line and brass hose fitting set up for tuning purposes for this very reason. I eveb tried some anti sieze on the flares to get them to stop cinching up to no avail. The only way I've found to stop the inlet fitting from spinning is to use a small pair of needle nose vise grips to hold the fitting while turnig the flare nut with a tubing wrench. Takes little practice but works. Whoever did the deseign of the sixpack carb spacing should be taken out and
Re: Help: Six-Pack Fuel Lines [Re: Classof70Chally] #103323
08/12/08 08:29 AM
08/12/08 08:29 AM
Australia
charger RTSE Offline
Australia
I did exactly the same thing twisted my fuel line.
I purchased a new fuel line and bought the right size pipe wrench spanner.For the carb side i got a spaner that fit on it and then went to work with a grinder and ground the spanner down to fit,
I now have my own home made tool for the job.
You will need to do this if your changing your jets or power valve around a bit.
Re: Help: Six-Pack Fuel Lines [Re: charger RTSE] #103324
08/12/08 09:41 AM
08/12/08 09:41 AM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Thanks a lot guys for the answers. I'll need to check out some tools to get these fittings off the carb it looks like.. Though I might have to start with the tubing cutter if nothing else works
Now, for the leak (pretty substantial now) that I seemed to have caused by trying to loosen the fittings at the front and rear carb ... Has this happened to any of you guys? I can't tighten (or loosen) the nuts now anymore, though I did put a good twist in the rear's fuel line. I can't get them to stop leaking now.
Does this sound like something that the new fuel lines I'm replacing with will help, or might I have damaged the fuel inlet adapters in the carbs by trying to turn the nuts on the lines? If so, I'll start looking around for replacemnts of those as well to be prepared.
Thanks much all for your help with this!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103325
08/12/08 11:08 AM
08/12/08 11:08 AM
buy a set of LINE WRENCHES if you dont already have a set. they are INVALUABLE for removing LINES
Re: Help: Six-Pack Fuel Lines #103326
08/12/08 11:17 AM
08/12/08 11:17 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Well, mine turned also and they were new. But I still went ahead and got the Promax line for mine. You can actually take any one of the carbs off and leave the lines attached to work on them. That's cool.
Moparlee
Re: Help: Six-Pack Fuel Lines #103327
08/12/08 11:41 AM
08/12/08 11:41 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Any chance you can post a photo so we can see what you're talking about? I think I know what they are...
Re: Help: Six-Pack Fuel Lines [Re: charger440sixpak] #103328
08/12/08 11:52 AM
08/12/08 11:52 AM
think of a 6 point box end wrench with a slot cut thru it for inserting it over the line. The slot is typically a little smaller than one on the HEX sides so you get maximum grip on the fitting
Re: Help: Six-Pack Fuel Lines [Re: Robbins] #103329
08/12/08 12:48 PM
08/12/08 12:48 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hey ... On those Promax Braided Lines ... How difficult is the install for them?
Specifically, can you just use your stock lower metal lines (the one that rounds the distributor) or do these lines go all the way down to the fuel pump/vapor separator?
Also, on the fuel inlets to the Carbs -- how do the Promax lines fit in there? Do they have new adapters or screw into the existing stock type ones?
Thanks a lot!
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103330
08/12/08 12:49 PM
08/12/08 12:49 PM
i like those too! what size are they?
Re: Help: Six-Pack Fuel Lines #103331
08/12/08 01:23 PM
08/12/08 01:23 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
line wrenches wont make a bit of difference. its the big fitting in the fuel bowl that starts to spin and its hard to hold them in place.
use a small tubing cutter and just put the new lines on. the line to the rear carb goes on one way. one end is stightly longer then the other and could make you crazy if you dont notice it. put the lines together hand light till its all back in place then tighten everything down
if your acc pump is leaking, i would really consider doing a rebuild on all three carbs while your at it
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103332
08/12/08 01:28 PM
08/12/08 01:28 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Not difficult....but I didn't try using factor stuff. My whole fuel system is custom, so.............
Moparlee
Re: Help: Six-Pack Fuel Lines [Re: Robbins] #103333
08/12/08 01:41 PM
08/12/08 01:41 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Ok, thanks guys for the great info.
Have you guys ended up with fuel leaks when you've tried (unsuccessfully) to loosen the lines at the carb inlets? I couldn't loosen them (they just spun), but now they are leaking like crazy. I can't tighten them either...
I'm resigned to just cutting the lines off now..but does it sound like something else could be going on now? Like the fuel inlet adapters shot?
Thanks !
Re: Help: Six-Pack Fuel Lines [Re: dg_dodge] #103334
08/12/08 02:04 PM
08/12/08 02:04 PM
Texas
bogusracer Offline
bogusracer  Offline
Texas
Look, If your trying to remove the carbs from the intake, then get a 1/2" line wrench and disconnect the rear carb from the brass "T" Block that connects the center and rear carb. Then remove the intermediate carb line (between the front and center carb "T" Blocks at the brass "T" Block to the center carb.
Doing this will allow you to remove the carbs. Start by removing the rear carb, then the front and last the center.
This will allow you to replace the lines you want to and get them tight on the "S" lines with trial and error fitting before final assembly to the intake with carbs and lines.
If you try to remove the lines at the carb bowls with them installed on the car you'll end up with leaks unless you "custom grind" some clearance on the outside of your line wrenchs, so they will fit into the tight squeeze with the carbs installed on the intake.
Hope this helps.
Bogusracer
