Re: thumper, fenderwell guys exhaust pics wanted [Re: Cab_Burge] #1031624
07/13/11 10:39 PM
07/13/11 10:39 PM
Engine shot of the low deck stroker with the SR heads, I had to raise the front of the motor up some( 1 inch to maybe 1.5 inches) to clear the headers off of the fenderwells with the low deck block Motor is moved back about 1 inch from stock A body location so that may be part of the fenderwell clearances with the low deck blocks
Re: thumper, fenderwell guys exhaust pics wanted [Re: Cab_Burge] #1031625
07/13/11 10:39 PM
07/13/11 10:39 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Here is a current picture of my car with the Hedmans for the Indy heads and the non coated extension I had to have made to hook the Hedmans to the old (current) 3 inch exhaust system
is it painted black because i cant see an exhaust in the pic. i like the stripe on the car
Re: thumper, fenderwell guys exhaust pics wanted [Re: sixpackgut] #1031626
07/14/11 12:40 AM
07/14/11 12:40 AM
Hedman coated the headers, they are black Local shop did the pipes and mufflers, black also. Stealth mode, you know Thanks for the compliment on the stripes, it does help it some
Re: thumper, fenderwell guys exhaust pics wanted [Re: rickma] #1031627
07/14/11 01:08 AM
07/14/11 01:08 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
69 dart
Rickma,
Which Headers are those? I have proparts for my Cuda, but was thinking about going with something different.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: thumper, fenderwell guys exhaust pics wanted [Re: FastmOp] #1031628
07/14/11 01:17 AM
07/14/11 01:17 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Mine were 3.5 pipe to bullits and turndowns pointed under the car.
Picked up .15 and almost four MPH building my own headers.
do you have pics of your headers
who kit did you use ?
1.39 9.85 - 137 mph
Re: thumper, fenderwell guys exhaust pics wanted [Re: Ari440] #1031629
07/14/11 01:32 AM
07/14/11 01:32 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
My car has Hooker Fenderwells with 31/2 Borla Race Mufflers
Re: thumper, fenderwell guys exhaust pics wanted [Re: cheapstreetdustr] #1031630
07/14/11 02:40 AM
07/14/11 02:40 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
im not a big fan of the exhaust dumping in front of the rear tire....any motor issue and you got oil all over the rear tires....my
cheapst.
I didnt really think of it like that ever, but now when it comes time to do my exhaust, im not dumping it out the side.
Fenderwell headers go in tomorrow hopefully
Re: thumper, fenderwell guys exhaust pics wanted [Re: GTSDave] #1031631
07/14/11 11:17 AM
07/14/11 11:17 AM
Butler Pa. USA
rickma Offline
rickma  Offline
Butler Pa. USA
They are Pro parts
Re: thumper, fenderwell guys exhaust pics wanted [Re: rickma] #1031632
07/14/11 05:14 PM
07/14/11 05:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Cab that's the 1st time I ever seen your car
Ari I sent you a PM
Re: thumper, fenderwell guys exhaust pics wanted [Re: 69B3GT] #1031633
07/14/11 05:47 PM
07/14/11 05:47 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
cheapst.
Exactly. Also if you don't have turnouts then you are spraying condensation and unburned fuel right at the tires. Notice that when you stick your hand behind tail pipes it often gets wet. You want that on your tires?
