several questions about 451 parts and driveability
#1027789
07/07/11 07:04 PM
07/07/11 07:04 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
My project is suddenly suffering a direction change
I have... 452 heads (working on porting and large valves ), 280/474 MP cam, 175K MP converter, stock HP exhaust, performer intake, FBO ignition, MP dist, 2.5" exhaust with SS flowmonster mufflers ( similar to magnas ).
will keep 400 rods.
was to build a 400 with 383 forged crank and KB240s, but SUDDENLY and by mistake the crank was a 440 forged. so now thinking on a 451, but ON THE CHEAPEST as posible, so KB is my option
KB215 are on mind due the lower CR with stock not milled 452 heads ( iron )
CAR IS FOR TOTALLY STREET USE. will keep the A/C.
Opinions about KB215s and complete DRIVEABILITY assembly... It's nice some noticeable iddling, but want to keep a streeteable 800 rpms at iddle not excesively "jumpy", just noticeable, and safe to run the AC once turned on.
is that posible and real ? or Am I getting into troubles and dreaming because is unreal to get a nice and soft iddling from the stroke I'm trying to build ? thanks...
Re: several questions about 451 parts and driveability
[Re: Carsavior]
#1027793
07/08/11 12:46 AM
07/08/11 12:46 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I built mine with 440 Manley rods and Ross pistons- they have them ready-made. Cut the mains to 400 std size and trim .120 off the counterweights. I did that and the shop that balanced it put two small holes in the crank- said I coulda drove it like it was, it was that close. I've had mine since 02, and love it!
This is how i did up my 451 useing 440 rods & ross pistons & 440 steel crank, had .120" cut off the counterweights, this makes the best power this way, lighter pistons & crank, hardly needed anything to balance it out, Compression came in at 9.73 with 92cc 906s & a .039" gasket, That 274H cam will be VERY mild but with exhaust manifolds & a small stall & little gear should work good, I ran the 284H with a 11" 3000 stall & it pulled 1.57 60ft. times with 4.10 gears, thats how much torque it produced, M1 single & a 750dp.
[Re: JohnRR]
#1027796
07/08/11 10:49 AM
07/08/11 10:49 AM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
I just looked at the Ross website as saw that.
So flat top with open chamber? How does this work? Do you mill the head or what?
[Re: NachoRT74]
#1027798
07/08/11 04:32 PM
07/08/11 04:32 PM
joedust451
super gas
super gas
Branson, Mo.
will keep 400 rods.
I'm sure it'll be fine if those are the pistons that'll work with the 400 rods, its just that "most" build them with the ross/diamond FTs & use the 440 rods & turn the counterweights down, I know your looking on the cheap, but how cheap is cheap , I only had a grand total of 3600.00 in my 451, & it was quit mild with the XE284H, The cam you have is mild & should be fine.
[Re: 2734bbl]
#1027799
07/08/11 04:36 PM
07/08/11 04:36 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
It'll work fine , just no quench unless you use a closed chamber head or mill the bleep out to the heads , but that will take away piston to valve clearance and raise your compression.
Quench is overrated , I seen it posted on the internet so it must be true .
[Re: NachoRT74]
#1027800
07/08/11 04:38 PM
07/08/11 04:38 PM
JohnRR
all coments are nice and welcomed , but wondering.... Is there something more to say about what I'm asking ?
what's more to say other than your cam and convertor choice could be better . the engine you are building is nothing more than a .035 over 440 wit ha short rod , nothing special or exotic .
[Re: JohnRR]
#1027802
07/08/11 05:19 PM
07/08/11 05:19 PM
NachoRT74
Valencia, España
but with more than a stock 440 CR
actually thats something nice, because I'm searching for something like a sleeper 400 , with a slightly funny iddle but hard to notice, and safe for the A/C
cam and convertor... actually I know maybe there are more aftermarket parts what maybe will suit better, but initially I wanted to build the engine with the more MP parts as posible
[Re: NachoRT74]
#1027803
07/08/11 07:09 PM
07/08/11 07:09 PM
joedust451
super gas
super gas
Branson, Mo.
How far do those KBs sit below deck with a 400 rod? If there not too low you'll still be good, Say if there around .060" below you'll be around 9.1-9.2 with un-milled 452s, Thats a good ratio for pump premium, Have you checked into this? If you want a dosile style cam, The XE268H should work great with AC, little gear & stall, The XE274H will still work VG (of coarse a bit better) even with what you have, but it'll have a "slight" rump, Just shoot for at least a true 9.1 so it'll have VG torque, Myself on such a mild build, i'd pass on the RPM & just run a Perf., shift it out at 5500 & smoke the *hit out of the tires all the way down the block . Just looked up those pistons , I'm not real familiar about the ending stroke useing a 400 rod & 440 crank, Does it still come out too 3.75 ?? If so, with a 90cc head you'll be at 10.4, that will not work with pump premium, plus its way too much cranking pressure with a smaller cam like your wanting. http://kb-silvolite.com/kb_car/performance.php?action=details&P_id=32This would be a better choice if the stroke is 3.75, I ran these in a 446 & on pump premium. These are basically the height of a six pack piston. http://kb-silvolite.com/kb_car/performance.php?action=details&P_id=30Heres another option, you can milled the heads too 85-87cc & be over 9.1 http://kb-silvolite.com/kb_car/performance.php?action=details&P_id=26
[Re: joedust451]
#1027805
07/08/11 07:31 PM
07/08/11 07:31 PM
NachoRT74
Valencia, España
440 rods are AT THIS MOMENT not an option.
but now, another question... how if 10-10.5 CR compromises the pump gas option, if I have seen ppl posting about their 10 CR engines being built all around, and everybody says they are gas pump friendly ?
BTW, we use here 91 and 95 unleaded gas
[Re: NachoRT74]
#1027806
07/08/11 07:32 PM
07/08/11 07:32 PM
joedust451
super gas
super gas
Branson, Mo.
actually dunno, KB doesn't say that, just says 10.4 with 90 cc and .030
Like I said, wayyyy too much compression for what you want, you will not be happy rattle-rattle-rattle You'd need a cam with at lkeast 250s dur. @50 & alot of overlap to bleed off pressure.
[Re: NachoRT74]
#1027807
07/08/11 08:01 PM
07/08/11 08:01 PM
joedust451
super gas
super gas
Branson, Mo.
Most likely there guessing on that do to the misconception, The gas today is CRAP this we know, & you will not see any perf. gains from a true 9.7.1 too 10.4.1 trust me, plus you risk the chance of detination, is that risk worth it, thats your call, I've done up a few of these 440s & with a true 9.7 your at risk especially with a small cam, even on premium 93, basically on the ragged edge. My 451 had a true 9.73 & it was fine on 93 as long as i didn't run it hard or ran the timing down a bit & set a conservative curve (this was with the XE284H) 185-190 cronking pressure, So i ran a small mix 75/25 of 93/110, Unless your running Aluminum heads, you need to be careful, try not to exceed 160-165 psi, don't risk it for a gain you will not see, a true 9.6-9.7 446 will be a total torque monster & I will put my word on that, This is the True compression ratios of a factory 440 with open chsmbered 90-92cc heads.
early yrs. 68-71 8.6-8.7 standard reg. fuel Six pack. 9.6-9.7.1 Premium only Later smoggers 7.6-7.8.1 Piss an option
[Re: joedust451]
#1027808
07/08/11 08:58 PM
07/08/11 08:58 PM
NachoRT74
Valencia, España
really appreciate all your opinions and experience... THANKS!... Just waiting for hear more opinions and experiences about this.
