Re: Stroker Hemis, What do you have?
[Re: dm69charger]
#1027466
07/07/11 05:23 PM
07/07/11 05:23 PM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
KB block 572" Hemi built by me. Callies crank, Oliver rods, Diamond pistons. 11:1 compression for 93 octane ONLY. MP heads, DLI rockers, custom Comp Cams solid roller. Indy -4 intake, Pro Systems dominator, 2 1/4" headers, 4" exhaust w/ mufflers. 727 trans, custom 9" 5k stall, 4.10 gear Dana 60, Cal-Tracs suspension, 295-65 drag radial. Best of 9.54 at 140.4 mph at 3800#. The motor is getting a little tired after a few years of beating on it, but it did go some 9.60s at 140 mph last November. I'd rather just drive it for now. Working on my other road runner to go racing w/ soon.
[Re: an8sec70cuda]
#1027467
07/07/11 05:53 PM
07/07/11 05:53 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
477 inches, 4.15 stroke 4.28 bore, stock 66 block, callies crank, manley/barton rods, je 12:1 pistons, stage v heads (very mild port work) bullet cams solid flat tappet 313/667, mopar performance x ram, stock 4235/36 carbs, clay smith mechanical fuel pump, hooker 5210 headers, tti 3 inch with x pipe to the bumper, dana 60 with 4.10,s/s 02 and 03 springs, joels on joy 727 with t/a 509j convertor, been best of 10.47 @ 128 on radials all on 4 wheel 11 inch drum brakes
[Re: B G Racing]
#1027468
07/07/11 06:36 PM
07/07/11 06:36 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
494,500,526,528,540,572,588,605,632,
[Re: prochargedhemi]
#1027469
07/07/11 07:19 PM
07/07/11 07:19 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
BG RACING built the little one a 588" in the Duster
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#1027470
07/07/11 07:21 PM
07/07/11 07:21 PM
HEMIFRED
SOUTH JERSEY
Then the 4.5" x 4.750" stroke 604" by DTHEMI
[Re: HEMIFRED]
#1027471
07/08/11 12:08 AM
07/08/11 12:08 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Well I don't know what mine will do yet as I'm waiting on some small stuff. Got a set of Indy/Canfield heads and a custom comp cams solid roller from Bob George to help get this thing to move. The rest of it is a MP 4.50 block, 4.15 crank, Milodon dual line oiling with 12 quart pan, windage tray with scraper. V series bearings, Manley 6.965 rods, 10.4-1 JE pistons with .990 pins. 2-1/8x34x3-1/2 headers, Weiand tunnelram with 2 850 thermoquads. Truck should weigh in at about 3650, 4-link, 4.56 dana, Torqueflite, 8"TA convertor, on 14x32.5 M/T radial drag slicks.Dave
