Re: What do ya think of my shroud ?
[Re: 383man]
#1026548
07/05/11 04:30 PM
07/05/11 04:30 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: stumpy]
#1026551
07/05/11 05:26 PM
07/05/11 05:26 PM
Challenger 1
Cincinnati, Ohio
Slick job. What did the shroud come from?
nice job on the shroud.
I hate to say it, but your fan sucks. It won't move as much air as stock 7 blade "216" fan will, I'm sure.
[Re: Challenger 1]
#1026552
07/05/11 05:33 PM
07/05/11 05:33 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Ron is that a flex fan I see?The shroud looks good.I have a stock C body one on my 65 B with a stock C body rad.Just wondering about the fan because I run a big SS one and never even come close to getting hot.Rocky
Chrysler Firepower
[Re: stumpy]
#1026553
07/05/11 05:37 PM
07/05/11 05:37 PM
383man
Balt. Md
Well it was laying on the ground next to a 96 Dakota truck. I just grabbed it and took some measurements and figured I could make it work. Cost me $11 dollars. Ron
[Re: therocks]
#1026554
07/05/11 05:42 PM
07/05/11 05:42 PM
383man
Balt. Md
Yes it's the only fan I have at the time as its the one that came on the car. Seems to pull alot of air and work ok. I plan to try a different one also when I get my hands on another one. Maybe one of the 7 blade ones ? I went to the shroud hoping to keep it cooler idleing in traffic. Ron
[Re: JohnRR]
#1026556
07/05/11 05:52 PM
07/05/11 05:52 PM
383man
Balt. Md
I plan to look for a 7 blade fan at Carlisle this week. Ron
[Re: JohnRR]
#1026557
07/05/11 06:00 PM
07/05/11 06:00 PM
Posts: 4,588 St. John's Newfoundland
440newport
I find the 70's-80's 5 blade clutch fans work just as well or better. I had a '68 BB solid 7 blade on my 80 Mirada 360 without a shroud and the temp would creep up pretty quickly when stuck in traffic. I later added a shroud which helped but didn't cure it. I then tried swapping to a 5 blade fan off a 5th avenue with a questionable fan clutch and the problem went away.
Before I would be over 200* in a matter of minutes, now it won't go over 180-190 no matter how long it idles. I'm not sure why it works better though. I think the clutch fan is a bigger diameter and the pitch must be more aggresive.
[Re: Kilroy was here]
#1026560
07/05/11 06:30 PM
07/05/11 06:30 PM
383man
Balt. Md
I think that shroud looks great, and a good fit, looks 'factory'.
Thank you. Ron
[Re: dogdays]
#1026562
07/06/11 01:14 PM
07/06/11 01:14 PM
therocks
Niles , Ohio
Ron I run a big ss flex from Summit on the 65.Even when its 90s out it runs at 180 190 all day.I even have an untouched 65 rad in it.I just hear people here ragging on flex fans all the time.Mine has been on at least 10 years and never any problems.I bet that new stroker really screams.Rocky
Chrysler Firepower
[Re: 70Cuda383]
#1026565
07/06/11 01:55 PM
07/06/11 01:55 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
PLEASE get rid of the flex fan. A friend of mine had one on his brand x car. Revved the engine, then we heard this odd sound.... The fan came apart, and actually punched a hole in his STEEL hood! Part of the blade was still stuck in the hood. Now imagine what would have happened if someone was underhood at the time.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#1026566
07/06/11 02:42 PM
07/06/11 02:42 PM
therocks
Niles , Ohio
Well I had a factory fan break on me.It was at startup and was only 6 years old.Ive run flex fans for years.My Jeep was a daily driver plow unit.It ran a flex that I pulled from the 65 that was 7 years old and it was on the Jeep for another 6 years.Cheap fans of anykind can break.I run stainless heavy duty only.Rocky
Chrysler Firepower
