Re: What do ya think of my shroud ?
[Re: 383man]
#1026567
07/06/11 07:37 PM
07/06/11 07:37 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Ron, shoot me a PM with the diameter of the hole in your shroud. I've got a clutch type fan off a C body that will move some serious air. It's a big fan. If it'll fit your shroud you can have it.
[Re: 383man]
#1026571
07/07/11 01:29 AM
07/07/11 01:29 AM
Posts: 7,664 IN
ahy
IN
I actually went with the electric fan for when I was stuck in traffic as I will just flip the switch and run the electric fan in traffic as I have it on a toggle switch. Thats why I stayed with the flex fan as it does not rob much hp at the track and the electric fan will move air when in traffic. But this new stroker seems to run a good 10 degrees hotter then the old 440 did so thats why I made this shroud to help the air go over the rad and not around it. Today was very hot and I drove it all around. Never went over 200 even sitting in traffic for 5 to 10 minutes without moving. But I may still try a better fan to see if it runs even cooler in traffic. Thanks for all the replies. Ron
Under 200 degrees in traffic sounds great. Maybe you can ditch the electric fan now. I wouldn't even worry about 210 as long as it cools on a roll. Shroud looks like a good fit.
