Re: Best valve cover gaskets for RB
[Re: sg66mopar]
#1026093
07/06/11 04:48 PM
07/06/11 04:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i have been using the same thick black ones forever it seems
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1026094
07/07/11 02:28 AM
07/07/11 02:28 AM
Posts: 296 Ontario Canada
Hutch
Ontario Canada
I tried the blue Moroso gaskets and I thought it was going to be the end of the problems. They lasted 1 day and then started to completely delaminate from the steel core. I sent them back as suggested and got told I had a fuel dilution problem ![](/ubbthreads/images/graemlins/shock.gif) and it killed the polymer. What the F ? I said just keep the gaskets , keep the money ,weak excuse, ![](/ubbthreads/images/graemlins/2516024-blahblah.gif) I will get this sorted out one day. So far a homemade set are hanging in there made from some old steam gasket paper. Hutch
[Re: Performance Only]
#1026101
07/10/11 04:01 PM
07/10/11 04:01 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Absolutely right Dan ![](/ubbthreads/images/graemlins/thumbs.gif) This particular gasket will NOT seal on a OEM unmachined gasket rail or with Stamped Steel valve covers! My belief the material feels so much thinner than the standard .060" thick cheap paper gaskets others use because of the high rubber content and excellent flexability of our premium material. Coupled with the Stick Resistant coating. When these are in your hands there is no doubt they feel VERY different than what most are accustomed to using. Thanks for ALL the great replies! Greg ![](/ubbthreads/images/graemlins/beer.gif)
