69 440 Cuda Motor mount
#1025831
07/04/11 05:06 PM
07/04/11 05:06 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
My 69 440 cuda driver's side motor mount is starting to deteriorate. I want to fab a new one, and make is solid, but mine looks like it has stretched. Can anyone tell me the correct thickness? Thanks, Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
Re: 69 440 Cuda Motor mount
[Re: mikemee1331]
#1025833
07/04/11 05:39 PM
07/04/11 05:39 PM
69Mcode440
Cedar Rapids, IA
Wow, that was quick!! Thanks alot!! Mike
[Re: 69Mcode440]
#1025834
07/05/11 01:39 AM
07/05/11 01:39 AM
Posts: 1,187 USA
big-block-dave
USA
Mike, M-code 'cuda!!! Are you looking for a NOS rubber insulator? I think Michaels motor parts has some? I think $135............Anyways read the bottom of my post. I don't recognize your name off the top of my head, if your car isn't in there, we'd love to add it!! Just added a new FB, owned since '78 with 8334 original miles!!! Let me know, PM me, i'll give you a email address i have just for the registry. Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: mikemee1331]
#1025835
07/05/11 03:20 PM
07/05/11 03:20 PM
Posts: 75,280 A gulag near you.
JohnRR
A gulag near you.
amazingly i'm sitting here at my desk with a new set of Anchor mounts from Rockauto with a tape measure in the drawer! the rubber insolator plus the top metal mount (the part with the attaching bolt is 1 1/4 inches.
Interesting as I just checked rockauto and they only list the right mount for a big block A Body , not the left as the OP asked about.
I won't be able to compare the NOS left I have to anchor right to see if they are the same thickness till tonight.
[Re: JohnRR]
#1025836
07/05/11 07:37 PM
07/05/11 07:37 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
the OP was talking about the rubber isolator, not the entire mount. the isolator is the same for both sides.
[Re: mikemee1331]
#1025837
07/06/11 09:22 AM
07/06/11 09:22 AM
JohnRR
A gulag near you.
NO, it is not the same for the both sides on a factory big block A body, 383 or 440, which is what the op is asking about.
[Re: scatpacktom]
#1025844
07/06/11 05:25 PM
07/06/11 05:25 PM
JohnRR
A gulag near you.
No repop available? I am going to need one.
Schumacher is working on one , they have a mount that will work but you need to modify the bracket as it only has one bolt to the engine bracket and it might be a tad shorter so it'll need a shim. I have it in my Dart currently , I'm not sure yet if it's the idler arm arm not being correct , it's not , or the mounts, as to why my centerlink is kocked and the idler hits the pan.
I'm going to be pulling it out soon if you want to try it out .
[Re: scatpacktom]
#1025848
07/06/11 06:07 PM
07/06/11 06:07 PM
JohnRR
A gulag near you.
I will find out soon enough then.
Is the trans mount unique as well?
I just looked , looks like the polylocs are the only replacement for stock , the trans mount is not unique though.
What is listed as the ORIGINAL mount is the one I have , it uses 1 bolt to the mount bracket and it's in a different spot , I had a spare bracket I modified instead of buying theirs .
[Re: JohnRR]
#1025849
07/06/11 07:57 PM
07/06/11 07:57 PM
mikemee1331
bethlehem pa
i stand corrected. the refference i was looking at shows no difference between 69 and 70 a or e and then it shows the same for b and e big block. (just goes to show ya how little i know about the 'toy' cars )
