68 b-body engine&trans (number match)
#1023528
06/30/11 04:30 PM
06/30/11 04:30 PM
Posts: 338 Bellevue,Mich.
Dodge33
Bellevue,Mich.
hello, looking at a 68 coronet 383 auto, ![](/ubbthreads/images/graemlins/thumbs.gif) the engine number is on the rail above the oil pan rail passenger side? the trans 727 is the number on passenger or drivers? it is above the pan rail correct? WHAT SHOULD THE NUMBERS BE?ANY HELP OR PIC'S WOULD BE GREAT.THANKS FOR YOUR TIME.
Re: 68 b-body engine&trans (number match)
[Re: topside]
#1023531
07/01/11 07:41 PM
07/01/11 07:41 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
For a '68, lay on top of the motor and look at the bellhousing/block mounting flange, driver's side of center. On BB cars, near the oil PSI sender area. Look for something like 8X123456 (year/plant/last 6 of VIN).
and a auto trans will be stamped on it's bellhousing in the same area, 4 spd's will be stamped on the machined pad.
[Re: FJ5_Fish]
#1023533
07/01/11 10:10 PM
07/01/11 10:10 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
V.I.N.: Last 8 digits of V.I.N. found at top of Automatic in 1968 up until about May 1968. This is the same situation with the digits as the engine block.
I agree, my 68 Road Runner with a May 4 build date has the numbers stamped on the top of the transmission housing.
[Re: rrunner]
#1023534
07/02/11 03:25 AM
07/02/11 03:25 AM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
My 68 has the numbers in the same area and on the pad on the side of the 4spd trans. My car built in the Los Angeles plant January 68.
