Re: Safe 5 point harness install without rollbar? [Re: ThermoQuad] #1023130
07/04/11 06:39 AM
07/04/11 06:39 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Seat belts in use at Watkins Glen International Raceway.
Can your Charger do this???
Re: Safe 5 point harness install without rollbar? [Re: ThermoQuad] #1023131
07/04/11 09:15 AM
07/04/11 09:15 AM
Locomotion Offline
Locomotion  Offline
It would appear that the further back you go with the shoulder harness mount, the less lateral support your torso will get. Not a good idea to focus on only frontal impacts.
I think that the shoulder belts should also help hold you "down" in conjunction with the lap belt. That may be why the mounting point in drag racing is suggested to be a little behind and below the shoulders. Spreading the loads out will reduce injuries.
