Is it normal to have slop in the steering wheel?
#1022683
06/29/11 12:42 PM
06/29/11 12:42 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
I have a 71 Road Runner. With the steering shaft hooked up to the steering chuck/spline shaft there is about 1/4-1/2 of slop when you turn the steering wheel either way before the splined shaft on the steering chuck even begins to move. Is this normal or should the parts that are in the greased (4 inch metal connector) that goes onto the splined shaft have no play in it at all? I watched the parts in this 4 inch metal connector, where the greese is turn loosely 1/4-1/2" before they start to get tight. All parts have just been rebuilt from steering wheel all the way down including the steering chuck so there is no old worn out parts.
Thanks,
Wizard
Guns, God, and Country.
U.S. Veteran
Re: Is it normal to have slop in the steering wheel?
[Re: Wizard]
#1022684
06/29/11 02:21 PM
06/29/11 02:21 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
The coupler should pivot around a little, but should have NO rotational slop. Sounds like it,s assembled wrong or worn.
[Re: StukaJU87]
#1022687
06/30/11 02:08 AM
06/30/11 02:08 AM
Wizard
Dillsburg, PA
Okay, is there a certain way the shoes should go in? Been awhile since I rebuilt this thing. Is one side of shoes curved? If so which way would they go in the coupler?
Wizard
U.S. Veteran
[Re: 1_WILD_RT]
#1022693
07/01/11 05:19 PM
07/01/11 05:19 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
I would ditch it for an aftermarket coupler. The firm feel piece is pricey but works very well.
The stock piece has worked fine in hundreds of thousands of cars for many millions of miles yet you feel it needs to be replaced... When assembled correctly they work fine......
just because something works doesn't mean there isn't room for improvement.
[Re: buildanother]
#1022695
07/02/11 12:54 AM
07/02/11 12:54 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I stand corrected. My brain cells seem to have see too much lead back in the day... Glad Jules is on the ball here..
[Re: sthemi]
#1022696
07/28/11 04:28 PM
07/28/11 04:28 PM
Wizard
Dillsburg, PA
Is there only 1 shoe spring for the shoes as shown in the picture from manual here?
wizard
U.S. Veteran
[Re: buildanother]
#1022698
07/28/11 07:00 PM
07/28/11 07:00 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Don't forget to pack that coupler with grease.
Scott
1969 Super Bee, 383/4 speed
[Re: buildanother]
#1022701
07/29/11 01:10 PM
07/29/11 01:10 PM
Wizard
Dillsburg, PA
Where can I buy one of these new springs? Mine is missing. Didn't get one in my rebuild kit. I tried R/T specialties on line but didn't see any. Maybe best to call. Don't really want to use a used one.
Wizard
U.S. Veteran
