Re: Really quiet muffler that flows 1/2 decent?
[Re: Coronet-R/T-Rag]
#1022478
06/29/11 11:48 PM
06/29/11 11:48 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The more I talk to him the more I think he is concerned with wanting them very quiet. I think I am going to look into the imperial mufflers.
[Re: gch]
#1022480
06/30/11 05:49 PM
06/30/11 05:49 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Here's the one I've been wanting to try: http://www.summitracing.com/parts/WLK-17853/?rtype=10It's 2 1/2" in, 2 1/4" out, 18" shell length. Lists to be a direct-fit for 68-76 Cadillacs, so it should flow pretty well if it was spec'd for that engine size. The Walker 17000-series is their turbo-muffler product line. $28 at Rock Auto, too!
[Re: JohnRR]
#1022482
06/30/11 08:45 PM
06/30/11 08:45 PM
Posts: 141 Ohio, USA
Donny
Ohio, USA
http://www.youtube.com/watch?v=3aiKrwGXFOo&feature=related
The above link is 3" exhaust with 14" Dynomax ultraflo muffler. Sounds rather loud to me. check his other videos, he has done alot of research on diffrent mufflers.
3" will be a lot louder than a 2.5, or 2.25 for that matter, system.
I just got into a discussion with a coworker (Ford racer) on this exact topic and he swears up & down that in regards to sound the size of the exhaust system has virtually zero effect on volume, it only effects the tone. I told him he was nuts. He's bringing me before & after video to watch of his Mustang when it had 2.5" and now with 3". He claims I won't believe my ears and is insisting just as a tip to not waste money on larger exhaust for purposes of sound alone. I'll see soon enough.
[Re: Donny]
#1022483
06/30/11 09:09 PM
06/30/11 09:09 PM
Posts: 21,823 Kirkland, Washington
Pacnorthcuda
The Ford racer is nuts. Given the same set up (brands/configuration) a change from 2.25 to 2.5 to 3.0 will make a BIG difference. I would not consider anything over 2.5 as quiet, it even in the 2.5 size you have to pic the muffs carefully if the motor is stout and you want quiet.
and not to go off-topic but once again I am reminded of my question Why no 2.75" pipes/muffs? Seems like such an ideal size. Not quiet though.
[Re: Tom Hand]
#1022484
07/01/11 12:58 PM
07/01/11 12:58 PM
Fury Fan
Indiana
HotRod Dave, if you want the best of both worlds, save your money and buy some of these. I can tell you all you need to know about them and how they work on my car.
Tom - Please give us the skinny on these. I searched thru some of your old posts for a clue but ran out of time.
[Re: 360view]
#1022486
07/01/11 04:14 PM
07/01/11 04:14 PM
Posts: 1,232 Chicago, IL
PLUM_72
Chicago, IL
I agree with 360VIEW, Use 2 mufflers. Remember back in the day they used a muffler and a resonator to quiet things. Two mufflers will do something similar. Find a decent flowing type. I would also add a cross-over or x pipe to help quiet things as well.
1972 Dodge Challenger
[Re: Fury Fan]
#1022487
07/01/11 06:51 PM
07/01/11 06:51 PM
Posts: 553 DE
Ply72rr
DE
Waldron’s Exhaust
[Re: Fury Fan]
#1022488
07/02/11 12:22 AM
07/02/11 12:22 AM
Posts: 271 MO, USA
Tom Hand
MO, USA
FuryFan, I made the set on my 69 Cuda and they are quieter than stock when closed and as loud as Flowmasters when open. They have zero resonation when closed and they roar when open. They flow like stockers when closed and even though this is not anything to brag about, they pass as much air when open as the equivalent sized Flowmaster. They are expensive but offer a person the way to have the best of both worlds. For sure, they are not drag racing mufflers, they were not meant to be. I did a lot of tricks inside of mine to bump the air flow up and the ones that Waldron sells are darn near as good, air-flow wise. For our A- cars, the 18" cases will fit fine although you need to drop the nose down a tad to clear the 4" actuator needed. For Bs, you could use the 19" or 20" case size. The sound levels depend upon engine of course but I saw around 9 to 10 dBa difference in many rpm levels on mine. The first video is a true 1970 400 VOE GTO. The second is my car with the stocker VOE mufflers. Mine are louder than the VOE GTO versions. The set below in the photo is on a 1969 Cobra Jet 428 Torino. http://www.youtube.com/watch?v=Mwov5Kp0SCEhttp://www.youtube.com/watch?v=oX5i4_CQqb8&feature=relatedTom Hand
[Re: 62maxwgn]
#1022490
07/02/11 09:32 AM
07/02/11 09:32 AM
Posts: 271 MO, USA
Tom Hand
MO, USA
And that is a great question 62MaxWagon. I (and Waldron's do I believe) use a 304 st. st valve plate mating with 409 st. st. tubing. The dissimilar materials keeps the sticking from occurring; indeed, it did in 1969-1971 when the parts were all 409 st. st. Both of these stainless steels are resistant to rusting all the way away. St. st. 409 builds up a surface condition of light discoloration/oxidation that then tends to stay put.
With the new fuels we have, the issue is not like it used to be in 1970. Plus, none of us fire up the car and listen and then shut them off. Okay, so I do to show off the mufflers' sound but I have no worries about them sticking as know what I did to them internally. Most of us tend to drive the cars and evaporate the moisture from the mufflers more so then what people used to do when these cars were new and used for transportation. A small hole will help if you just start and then shut the engine off.
My mufflers are now going on 6 years old. The originals in 1970 lasted about two to four years max (I heard) but tended to stick and required you to tap the end now and then to break them free. The new generation versions do not.
The cool thing is they stay closed while they sit and when they open or close upon driver control, they chatter briefly while seating and unseating the valve. The videos may allow you to hear the very brief rattle. That comes from the plate being free to float on its shaft letting it always take the correct angle needed to seat. This slight chatter also tends to polish away anything that may be starting to build up and change the surface and cause sticking issues.
The actuator is the part than can wear out but it is outside and easy to replace. A few of the very early ones needed a modification to the rivet that held the arm on the rubber diaphragm but that part is well understood and the engineering change was instituted several years ago.
I have attached the original patent illustration. You can see how they worked originally. The changes we made simplified them and made them much better, longer lasting, louder when open, and quieter when closed. Plus they flow more exhaust gases when open, and the new materiel we used makes them virtually "forever" mufflers, not short lived ones like they were in 1969-1970.
Tom Hand
[Re: HotRodDave]
#1022493
07/03/11 09:19 PM
07/03/11 09:19 PM
Posts: 15,864 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I also have Walker "quiet flow" mufflers on my MP Magnum 360. I would say they are definetly as quiet as an OEM muffler. As far as flow, I can't tell. They are the only mufflers I have had on this engine. As mentioned by another member, quality is not all that good. It has only been a few months and I can already see some rust beginning at seams.
Facts are stubborn things.
[Re: MadMatt]
#1022494
07/03/11 09:39 PM
07/03/11 09:39 PM
Posts: 271 MO, USA
Tom Hand
MO, USA
Madmatt, Good comments Matt. Here is why they are made like they are. A solenoid would cost more than the actuator plus the wiring and switch is more complex and expensive. The vacuum requires really inexpensive tubing and is simple to hook up and easy to adapt to anything. The 4" actuator lets cars with as low as about 10 inches of vacuum at idle easily build up enough vacuum in the reservoir to pull and hold them open. The spring that holds them shut has some force but the 4" actuator has enough "guts" to yank them open. Tom Hand
