Re: Need advice Jeep A/C inop
[Re: J_BODY]
#1022374
06/29/11 09:11 PM
06/29/11 09:11 PM
Posts: 2,138 tucson az
frank
tucson az
Just did one today...... and NO... I didn't use the scan tool. Comp didn't come on, front of clutch pulley was missing paint (hot), grabbed my dvom and since the connector is right there in front of your face ohmed it out and just as I thought, open. Installed a new compressor. We live in the desert, it's hotter-n-L, no way I'd risk installing an clutch coil only unless the customer signed a waiver stating that is what they wanted. Due to the heat involved when the coil bakes the front seal often will leak and create a "comeback".
Did you put in a new accumulator and orifice also or just the compressor. Dealer dropped their price by 150 and said I only needed a compressor because fluid was so clean; no need to replace other parts. Does this sound right?
[Re: 72chargerz]
#1022376
06/29/11 09:30 PM
06/29/11 09:30 PM
Posts: 13,878 Willow Grove PA
71sat440
Willow Grove PA
It is generally accepted standard procedure to replace the accumulator and orifice tube when replacing the compressor.
Where I work you get 0 warrenty if you do not buy both.
[Re: frank]
#1022381
07/01/11 09:27 AM
07/01/11 09:27 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We used aftermarket all the time at work.Most were from Advanced.Only had a few problems and probally replaced a few hundred total.That compressor should be an easy job.Have someone evac the system and change it yourself.Just make sure that the compressor has oil in it.Some do some dont.Really not a hard job.You will need to have someone pull a vacuum and recharge it after install.Rocky
Chrysler Firepower
