Re: Rear Main Seal Leak
[Re: bri440]
#1019752
06/24/11 04:35 PM
06/24/11 04:35 PM
RapidRobert
Prob have to drop the pan & basic visual & see what the prob is. Good luck, oil leaks are always a pain
[Re: bri440]
#1019755
06/24/11 05:44 PM
06/24/11 05:44 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
If I managed to reverse one of the main seals how bad would it leak?
BAD
The crankcase is vented, so there is no internal preassure pushing the oil past the seal.
There is still "some" pressure along with oil pressure and plenty of oil.
Take it apart and have a look-see. Inspect everything while you disassemble
[Re: GI Moparman]
#1019758
06/26/11 03:15 AM
06/26/11 03:15 AM
RapidRobert
I have not done it yet but it's been suggested to somwwhat smooth the serrations as they were for OE rope seals and will cause probs w the neoprene seals that most of us go w. That might exp why alot of leaks start after a bit of run time
