puting a 383 in 74 charger need oil pan #1019479
06/23/11 11:34 PM
06/23/11 11:34 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
any one know where to buy a 1974 chager oil pan car had a 318 in it want to put a 1967 383 I have in it . Will a stock 400 pan fit ? is the 383 pick up the same as 400 ? The 383 pan is dented and rotted . thanks guys
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: puting a 383 in 74 charger need oil pan [Re: sparcy] #1019480
06/24/11 12:31 AM
06/24/11 12:31 AM
(1) yes (2) yes. Only caveat is iirc a baffled pan needs a pickup w a diff bend than the pickup for a non baffled pan but 383/400/440 the same just need a regular center sump pan (sump actually somewhat forward from exact center) but is called a center sump as opposed to all the way in the "rear sump" (truck) and an all the way in the "front sump" (van). check the BB for sale section & for anything other than a DD a baffled pan would b a good choice & you can weld one in around the perimeter of the top of the sump easily & dont paint it until after you weld & weld slow/carefull to avoid warping the flange and buy a pickup for a baffled pan if you're adding em
Re: puting a 383 in 74 charger need oil pan [Re: RapidRobert] #1019481
06/24/11 01:26 AM
06/24/11 01:26 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
74 Charger used a special big block K frame. 318 frames will not accept a big block without custom mounts from Schumacher.
K frame and Oil pan from a Cordoba with a big block will interchange..
