B-body control arm differences? #1019313
06/23/11 05:57 PM
06/23/11 05:57 PM
Augusta, GA
Lightning Offline OP
Augusta, GA
got a question about B-body control arms,
what's the difference between the early and late versions? I know in '73 they switched to the isometric mounts, but I havent seen any comparison pics of the early and late control arms before. Are the later ones longer? do the mount in a different place (dimensionally)? etc.
Thanks!
Re: B-body control arm differences? [Re: Lightning] #1019314
06/23/11 06:15 PM
06/23/11 06:15 PM
Andrewh Offline
Andrewh  Offline
they are the same from 62 to 72.
Re: B-body control arm differences? [Re: Andrewh] #1019315
06/23/11 06:27 PM
06/23/11 06:27 PM
Augusta, GA
Augusta, GA
sorry, I was meaning to say: the difference from the '63-'72 version and the '73-'79 version
Re: B-body control arm differences? [Re: Lightning] #1019316
06/23/11 11:27 PM
06/23/11 11:27 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Its hard to explain without a pic, but, '72 back the camber/cast is adjusted by individual bolts with 'cams'. The '73-up control arm mounts to a shaft, and the shaft is moved on a slotted plate to make alignment changes.
The arm will not interchange due to the different mounting styles.
EDIT: Here's a link to a thread on another site that shows the differences: linky
John
Re: B-body control arm differences? [Re: SattyNoCar] #1019317
06/24/11 01:05 AM
06/24/11 01:05 AM
Augusta, GA
Augusta, GA
so then the late B- mounts just like the M-body upper arm then. Gotcha.
