Re: What's up with 512" combo's?
[Re: old yeller]
#1018054
06/24/11 12:45 AM
06/24/11 12:45 AM
Posts: 3,456 Out West
408strokerdart
Out West
so nobody likes the rb 512 or bigger is it cause the block(stock)webbing
about 25 years ago i had a 440 motor that had cracked webbing and i didn,t even know till i tore the motor apart for a fresh rebuild,when i pulled the crank out part of the webbing came out with it,myself i go with the low decks cause you can wing em like a small block chevy and rpm,s make hp,on motor i shift around 7,800 rpm,s, on spray its close to 9 grand,and i have yet to throw a rod(not saying it won,t happen)it just hasen,t happened to me in the last 5 years
Being a small block guy, I like RPM's. ![](/ubbthreads/images/graemlins/thumbs.gif)
