Re: 130lbs cranking pressure ????
[Re: Wedgeman]
#1016153
06/19/11 10:33 AM
06/19/11 10:33 AM
Posts: 7,506 Az
Crizila
Az
Well, at least you got the same problem in every hole. It's a pretty hefty duration & late intake valve closing, but you are still low IMO. What was the starter cranking speed? Should have been around 500rpm. Did you miscalculated the CR? How far are the pistons down in the hole? Dished pistons? Valve lash set correctly? You might want to run it in a bit and then recheck it. Don't know why you would want to check cranking compression on an engine with no run-in time on it?? - even though I don't think it will come up 60 psi.
Fastest 300
[Re: Crizila]
#1016154
06/19/11 10:41 AM
06/19/11 10:41 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
The base of the engine and rotating assy are the same as last yesr...
I double checked the calculations with the new cam specs and results should be there..
I only changed the cam and heads in the equation
Last year was a 250/250* dur cam with valve closing 71* ABDC
[Re: Wedgeman]
#1016157
06/19/11 10:58 AM
06/19/11 10:58 AM
Posts: 52,972 Romeo MI
MR_P_BODY
same piston and ring as last fall....
What did you degree the cam in at... sounds like its retarted
[Re: Wedgeman]
#1016160
06/19/11 11:34 AM
06/19/11 11:34 AM
MR_P_BODY
I just aligned the dots on the timing gear....
Could I loose 60 lbs if htey were misaligned ?
Dan
Off hand I would say that is your problem... needs to be degreed in
[Re: MR_P_BODY]
#1016161
06/19/11 11:38 AM
06/19/11 11:38 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your cam is retarded.
Once you degree it you will probably find it needs to be advance 4-6 degrees.
Leon
[Re: Leon441]
#1016162
06/19/11 01:01 PM
06/19/11 01:01 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
You cant always go by those calculators. What kind of formula are they using to figure this? There is diff types of compression for sure. Even if you advance the cam its not going to be 190 PSI.. It might gain 10 lbs...maybe.. Your over thinking it.. just run it see how it goes.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Leon441]
#1016163
06/19/11 01:04 PM
06/19/11 01:04 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I still don't think you are ever gonna get 190 PSI with that cam and that compression, mabey get close if you advance it a bunch but 10.5 and a cam that big ain't gonna do 190. I do agree it is low but not 60 lbs low. Should always degree it in and you need to re check piston to valve clearance AFTER degreeing it correctly.
[Re: Wedgeman]
#1016171
06/21/11 11:08 AM
06/21/11 11:08 AM
Posts: 16,930 NC
440Jim
NC
Cam gear was off one tooth ! got pressure back to 160
Good catch. It would have ran like a dog with 14 degree (1 tooth) error.
One tip. With aluminum heads and a cast iron block, I like to set the cold valve lash 0.004-0.005" tight, so that when hot it will be closer to the cam manufacturer's hot spec. Then check it hot for final setting.
