trans overflows after short time driving #1015107
06/17/11 02:22 PM
06/17/11 02:22 PM
Clinton Twp, Michigan
abodykid Offline OP
abodykid  Offline OP
Looking at buying a truck a guy has for sale...it has been pretty much rebuilt front to back. The guy is selling cause he has run out of patience and time to work on it.
The main thing wrong with it he says is that after a couple miles of driving it the trans seems to overflow out of the top...fluid looks bubbley if you pull the dipstick....says he has pulled the trans a couple of times...replaced the radiator....not sure what else to do and just wants to get rid of it......any ideas???
Re: trans overflows after short time driving [Re: abodykid] #1015108
06/17/11 05:35 PM
06/17/11 05:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Overflow out of the top" as in dipstick tube or bellhousing?
Bubbly fluid means it's aerated from being overfull, overheated or an internal leak.
Re: trans overflows after short time driving [Re: abodykid] #1015109
06/17/11 06:59 PM
06/17/11 06:59 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Replaced the radiator- is it replaced with a radiator with a transmission cooler or does it have and auxiliary cooler. Has to have a trans cooler.
Re: trans overflows after short time driving [Re: MoparforLife] #1015110
06/17/11 08:54 PM
06/17/11 08:54 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I wonder if he is filling it park or with the engine off, and therefor overfilling it. It shouldn't flow out of the dipstick tube, though since the case vent is a lower spot.
Re: trans overflows after short time driving [Re: abodykid] #1015111
06/18/11 12:04 AM
06/18/11 12:04 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
it's possible someone might have swapped the dipstick or tube also. could be "filling" it, with a different stick. (if they're available in different lengths ) foaming/bubbling is the sign of overfilled.
