Re: Sending Unit - Best Place to Buy and Questions [Re: RapidRobert] #1013532
06/16/11 07:46 PM
06/16/11 07:46 PM
Kirkland, Washington
Pacnorthcuda Offline
You can always make a new voltage limiter for the fuel gauge--adjustable and digital. Pretty easy. I have one on my fuel gauge.
In a nut shell it allows you to dial in a voltage anywhere from about 4-6 volts so you can boost or lower your gauge reading.
Doesn't solve linearity problems, but allows you to increase or decrease (but not both) the reading at any level.
Re: Sending Unit - Best Place to Buy and Questions [Re: Pacnorthcuda] #1013533
06/16/11 08:40 PM
06/16/11 08:40 PM
NJ
rth Offline
rth  Offline
NJ
my new one gets similar readings.took it back out and hooked up wires.key on operating by hand reading are good at gauge.put back in same crap.maybe topping out on tank?bend float arm thens hits pickup tube.wish i had orig to compare float swing.
Re: Sending Unit - Best Place to Buy and Questions [Re: rth] #1013534
06/17/11 08:47 AM
06/17/11 08:47 AM
Owosso, Michigan
stateroadhog Offline
Owosso, Michigan
wow hear we go borrowed a sending unit from friend. Stock 40 year old unit. diffrences are swing arm on unit 1/2 inch longer after radius.diffrent ohm readings on swing of old compared to new. measuring from center of float to pickup tube. slightly over 10 ohms diffrence in same spots along sweep. both read almost same at each end of sweep. old 80.8 new 77.9 on empty old 9.4 new 10.6. where it really varies is along sweep at 47 ohms on old unit gauge reads 1/8 tank on new at 49 it reads empty.
Re: Sending Unit - Best Place to Buy and Questions [Re: stateroadhog] #1013535
06/17/11 08:55 AM
06/17/11 08:55 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Has anyone tried to put the old swing arm assembly on a new pickup ?
Re: Sending Unit - Best Place to Buy and Questions [Re: JohnRR] #1013536
06/17/11 09:06 AM
06/17/11 09:06 AM
Owosso, Michigan
Owosso, Michigan
by the way the old sending unit makes gauge readings more accurate, not perfect but more usefull.not 8 gals left on empty. I also get diffrent readins on gauge when installed in tank as compared to on bench. yes good ground and 5 volts to gauge
Re: Sending Unit - Best Place to Buy and Questions [Re: stateroadhog] #1013537
06/17/11 01:33 PM
06/17/11 01:33 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Cut the swing arm assembly off a good factory unit and attach to the tube with screw type hose clamps thru the 2 slots in the swing arm assembly. And connect the wire to the repo strap type wire.
Re: Sending Unit - Best Place to Buy and Questions [Re: Crazy68Dart] #1013538
06/17/11 02:30 PM
06/17/11 02:30 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
We will be offering our 1/2" sending units for Mopar A-bodies in about a week or so. They are not on our website yet but will be similar to this one:
http://www.robbmcperformance.com/products/1084_fordsend.html
Will have 1/2" feed and return (AN fittings optional). The 1/2" return is handy if you are using a return/bypass style regulator.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Sending Unit - Best Place to Buy and Questions [Re: RobbMc] #1013539
06/17/11 06:29 PM
06/17/11 06:29 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Rob, you made my day. I was just on your website a few days ago hoping to find one, but didn't see it.
Can you PM with details, or throw it out here if you want for all to see? I am interested in a 1/2" feed with 1/4" return, AN option would be perfect.
I am confident that yours will read as it should, but tell me it will, just so I feel better.
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Sending Unit - Best Place to Buy and Questions [Re: Crazy68Dart] #1013540
06/17/11 06:47 PM
06/17/11 06:47 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
You can order it with or without AN fittings. You can also order it with a 1/2" to 1/4" reducer fitting for the return line. Cost will be $169 plus $20 for AN fittings. The reducer fitting is $6.
We have an A-body gas tank with a hole cut in the side so we can see the position of the float. We've tried to place the float very close to the bottom of the tank when the arm is at the bottom of it's travel and very close to the top when the arm is at the top of it's travel.
On our other sending units, we have found that it is common for the gauge to read a little higher or lower than with the stock sending unit (maybe 1/8 tank different) but if you feel it is too far off, you can return it and we will rework the arm. Bending the arm so the float is lower makes the gauge read higher. Bending the arm so the float is higher, makes the gauge read lower.
Everyone has a different opinion on how the gauge should read. I run our sending unit in two of my cars. I have them adjusted so the car runs out of gas when the needle on the gauge is right on the "E" mark. I prefer that over having the car run out of gas at some unknown point somewhere below "E". However, most people are accustomed to the idea of having a few gallons left in the tank when you get to "E" so that's how we try to set them up.
BTW, most cars sold in Europe have gauges that read "E" when you are actually out of gas but in the USA, gas gauges traditionally are set up so you still have a few gallons in the tank when the gauge reads "E". I wonder why?
Re: Sending Unit - Best Place to Buy and Questions [Re: RobbMc] #1013541
06/17/11 07:48 PM
06/17/11 07:48 PM
Canton, Ohio
Canton, Ohio
Your logic makes sense to me.
Can I PM you here, e-mail, or? When do you think the sending unit will be available (shipped) if I order in the next few days?
FWIW, I am soon to try your starter (I purchased it from you a few years back). That and your cap adapter.
Dunno, we drive a lot more automatics in this country too...
Re: Sending Unit - Best Place to Buy and Questions [Re: Crazy68Dart] #1013542
06/17/11 07:56 PM
06/17/11 07:56 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Dart,
Please email me for more info. Email address is shown here:
http://www.robbmcperformance.com/contact.html
Re: Sending Unit - Best Place to Buy and Questions [Re: RobbMc] #1013543
06/17/11 10:59 PM
06/17/11 10:59 PM
Owosso, Michigan
Owosso, Michigan
will you be offering 1/2 inch sending unit pickups for 70 b-bodys?
Re: Sending Unit - Best Place to Buy and Questions [Re: stateroadhog] #1013544
06/17/11 11:05 PM
06/17/11 11:05 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Only A-bodies for now. We may add other applications later.
