Re: Get yer Bulldog flow numbers here......
[Re: Dap]
#10154
02/08/04 11:56 AM
02/08/04 11:56 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
there seems to be a bit of confusion about these particular BD heads.
these heads were bought from MM by Dap, as a retail customer.
MM didnt know they were going to be shipped to me, or that they were going to get flow tested or scruntinized.
they were delivered to Dap(and then to me) in a "ready to run" condition.
my guess is that MOST of the BD heads that get sold, will be prepped by the retailer...not Bulldog.
[Re: fast68plymouth]
#10155
02/08/04 12:54 PM
02/08/04 12:54 PM
dartman366
Mt. Vernon, Ohio
Im' pretty new to this web site, but I have been reading alot of the threads on various things, and one of the most interesting things so far are about these bulldog heads, I am in the process of stepping up from my smallblock,J headed, 76 dart to a 89 daytona full chassis car, with of course a 400/496 stroker(one small step for mankind,one humongous leap for me!!!) and one of the biggest questions was, my pick of heads.Indys are out because of budget constraints, E-heads were the logical choice because most anyone that I talked to had good sucess with them, now comes the bulldogs and the only thing that I know about them is what I have read here. In your opinion would you think that I would still be better off starting with the E-heads and later progressing to the bulldogs once the bugs and gremlins are sorted out? plus seeing what you have come up with on flow numbers will give my engine guy somthing to work with, thanx
[Re: dartman366]
#10156
02/08/04 01:37 PM
02/08/04 01:37 PM
I too am cosidering picking these heads up. I have a 493 RB stroker motor with the Edelbrock heads. Personally I am going to wait and see if and when these bugs will be worked out. I dont want to take a set to my machinest and spend the money to find out that the head couldnt be ported correctly without making holes. Once they get this situation ironed out and Fast posts the Level 2 porting flow numbers it will be real interesting to see what these things can do. I will wait until a couple of members have good success with them before I spend my coin. I want to see how they fit as well.
#10158
02/08/04 07:28 PM
02/08/04 07:28 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Fast, are there any interesting pics to post yet?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
#10160
02/10/04 08:58 AM
02/10/04 08:58 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
So far the only price I have seen is the Hughes's 1850$ for the assembled pair. The Indy SR's are about 1800$ pair assembled. The Indys need longer pushrods, head bolts, oiling kit and valley cover. What do the Bulldogs need? Longer pushrods propablty because of the longer valves? How about the head bolts, can you use the factory ones with hardened washers? How about the exhaust flange location compared to factory iron heads? Is it higher? More outwards? Need for custom headers? I think the price is pretty close to that of the SR's, so that wouldn't lead my decision in which one to choose.
Plynouth VIP '67 TT IC EFI
[Re: CokeBottleKid]
#10163
02/15/04 02:25 AM
02/15/04 02:25 AM
ummm he didn't read the post correctly then, MOPARs don't lack a floor, the head was a bad casting and the floor was too thing.
Thanks, I will bring this detail to his attention.
#10164
02/15/04 08:59 PM
02/15/04 08:59 PM
It wasn't misread ![](/ubbthreads/images/graemlins/hammer.gif) The hole is in the exhaust port floor. All of the high flow heads either raise the port or add material to the floor for more short turn radius. Why would someone cut into the floor for more flow when having more floor adds flow
#10168
02/16/04 02:34 PM
02/16/04 02:34 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
oh...you must be new around here......
