Starting-from-scratch ....leafs, ladder or 4 link ....
#1013208
06/14/11 12:55 PM
06/14/11 12:55 PM
Posts: 30,556 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
..... in a door car(a very uNusual door-car indeed ) ... space might be a prob(very short rear overhang) uNless the springs were shortened on the back half. What would be the EZiest to do(for the chassis guy) ... and the cheapest as far as parts ?
Re: Starting-from-scratch ....leafs, ladder or 4 link ....
[Re: Cab_Burge]
#1013211
06/14/11 01:25 PM
06/14/11 01:25 PM
Posts: 12,424 Taxes & Virus's R-US, NY
Dragula
Honestly, I think the intended HP should be the final decider, but I love ladder bars for the ease of maintenance, adjustments, and just simplicity. We have started racing a 4-link car, I have to say, I do not have the knowledge at this time to get it set-up correctly. To say there are more adjustments, is an understatement.
Ultimitly, tire size and hp for your combination will be the factors. The four link will hook a small tire car with a lot of hp better than a ladder bar set-up, but a good ladder bar set-up can be really good as well.
If there is room for leafs, Caltracs and mono's are the way to go...
[Re: go green]
#1013212
06/14/11 03:09 PM
06/14/11 03:09 PM
Posts: 20,722 in a cattle trailer down by th...
Guitar Jones
Drinking in the morning is not a good way to start your day.
I see nothing wrong with it.
I always suggest to go 4 link. Reason being is why not just spend the couple hundred extra one time, then you have a suspension for life. Future power upgrades (and you know there will be some, don't kid yourself) are now not a worry because you will have the suspension to handle it.
Leafs and CalTracs? Only if you have to keep the leaf spring or just won't ever cut the car up.
[Re: go green]
#1013213
06/14/11 05:08 PM
06/14/11 05:08 PM
dOc !
Florida STAYcation
I think go-green has been sniffing tooo many of those NITRO fumes he burns in that 'Cuda !
[Re: Quicktree]
#1013215
06/14/11 07:51 PM
06/14/11 07:51 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
"Dave Morgan told me , when he spent a few days at my house...." OKAY,,let's hear ALL ABOUT the 'visitation',,,sounds 'gay' to me... Hope you all got the 'angle' right..!! I'm SORRY,,just couldn't help myself,,,
If you like drag racing, support your local track.
[Re: CHAPPER]
#1013216
06/14/11 07:55 PM
06/14/11 07:55 PM
Quicktree
thats because you are gay and think gay
[Re: dOc !]
#1013220
06/14/11 09:17 PM
06/14/11 09:17 PM
Quicktree
....should it have been mentioned that this is my mid-engined Caravan project ?
There is not a lot of area for the rear half of the spring in there ...
[Re: Quicktree]
#1013221
06/14/11 09:59 PM
06/14/11 09:59 PM
Guitar Jones
I've heard fat, drunk and stupid is no way to go through life...but it's worked out OK for me.
[Re: Quicktree]
#1013222
06/14/11 10:49 PM
06/14/11 10:49 PM
dOc !
Florida STAYcation
... the rear-half of a STD or even typical SS spring.
What are the typical costs of a 4 link kit that will be STREETED .... how about the spring-and shock combo?
[Re: dOc !]
#1013223
06/14/11 11:00 PM
06/14/11 11:00 PM
Guitar Jones
No more STD's please! Wear a helmet.
As for springs and shocks the price is the same if it's a ladder bar or four link. It's the rod ends that drive the price up. I suggest buying the best ones you can though. Springs and shocks you can cheap out on if its a street car and upgrade later if you want to get serious.
[Re: Guitar Jones]
#1013224
06/14/11 11:09 PM
06/14/11 11:09 PM
Posts: 2,177 ill
dennismopar73
ill
my first would be , sure go min of ladder bars, best option of 4 bar, then i think of all the money that had to be spend , and rethink it ,, LEAF SPRINGS!!!!!! MAKE THE CAR AS LITE AS STREET CAR COULD BE ,10"/11" TIRE 451 STROKE ON E 85 391=410 GEAR. HAVE FUN ON SHOESTRING FAST RIDE!!
[Re: Randy..]
#1013226
06/14/11 11:47 PM
06/14/11 11:47 PM
Guitar Jones
4 link, 300 adjustments and you will use about 3 of them, i would go ladder bar.
Maybe but those three adjustments will still work better than the one out of three you'll use on a ladder car.
Many here seem to make a big deal about adjusting a 4 link, it's not that hard and it's not rocket surgery either. Jeez, you own a race car, did you build it, work on it or do you just write a check and drive it? You guys make it out to be quantum physics or something.
