Re: Starting-from-scratch ....leafs, ladder or 4 link ....
[Re: Randy..]
#1013228
06/15/11 12:11 AM
06/15/11 12:11 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Some people has mention adjustable... It can be a problem. That little Dakota truck I had I went with Ladder bars. Ladder Bars can be pretty violent. It can be a problem to adjust down..up rather to tame the hit down. I say 4 link. Yea its a little harder to adjust, heck anyone can get ladder bars to hook... But the 4 link really enables one to infinite adjustment. I guess some times 3 holes isnt enough.. And with a weird mid engine application, 4 link is a Non Brain'r.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: dOc !]
#1013229
06/15/11 03:02 AM
06/15/11 03:02 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I vote 4 link.
As said above, it's not a "usual" combination and you have no idea, you just MIGHT NEED the adjustability. Better to have it IMO...
CrAzYMoPaRGuY
[Re: dOc !]
#1013231
06/15/11 10:09 AM
06/15/11 10:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Some times the space that you can play within dictates what suspension you can run... a 4 link takes less fore and aft distance BUT needs more vertical space where a ladder bar needs more for and aft but less vertical... on my Rampage I went with a ladder bar because of cost... I could have fit a 4-link in but I believe a anti roll bar is needed with a 4-link so thats added cost.... is a 4 link better... yes(and I have had both set ups on the same car)....this is JMO
[Re: dOc !]
#1013233
06/15/11 10:37 AM
06/15/11 10:37 AM
MR_P_BODY
THX guyz ....
Let me add something in here that MIGHT put the dampers on the 4 link ... a short driveshaft.
Just from eye-balling-it .... I might be dealing with a DS of something around 2.5 feet long. IF there is huge vertical movement ... with a short DS ..... will there not be severe U-joint issues ?
I do have the option of a short-shaft 727 .... but I would LIKE to be able to use a long-shaft.
I use a 38" DS on the P-Body with no issues... the DS on my Rampage will be about the same
[Re: dOc !]
#1013235
06/15/11 11:08 AM
06/15/11 11:08 AM
MR_P_BODY
What kind of vert movement is needed? ...less than with leafs ?
Alot of the shocks will have about 6" of total travel so as a round figure its 3" both ways from curb height
[Re: dOc !]
#1013236
06/15/11 01:05 PM
06/15/11 01:05 PM
Posts: 2,177 ill
dennismopar73
ill
..... in a door car(a very uNusual door-car indeed ) ... space might be a prob(very short rear overhang) uNless the springs were shortened on the back half.
What would be the EZiest to do(for the chassis guy) ... and the cheapest as far as parts ?
Nothin cheap about either 4 bar or ladder set ups 4 bar runs 500 and up ladders are 250 up, then depends on shocks you use, nothin easy about either one set up take awhile and very hard to do at the track for any novice guy with out knowlege and use of the product because so much has to be taken into account, shock setting evoke pinnion angle set bar hieght, evokes shocks it not as easy as any on here say, despite most guys do not even touch their bars , or very few who do , question always must asked is it the car? , track? tires? i know of several 4 bar cars that have not had bars reset in 10 years yet hook great and 60 dont change enough to warrent any , know of a guy who bought 4 bar car due to bad track , took the car to 2 diffrent chassie guys, had all the bars changed because they said the bars where to old and that was the reason the car wouldnt hook. by the time everyone got done with the car, he was out of money and was sick of the car it sets to this day, my car has ladder bars, coil overs, they where cheap ,@ 850$
[Re: dennismopar73]
#1013237
06/15/11 02:45 PM
06/15/11 02:45 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
I think this guy got taken for a ride, and not in a good way. Just because someone ripped him off is not a reason to dismiss the four link. It's just not that complicated, simple geometry. And I think your prices are off, do a little research, a four link back half is pretty much the same price as a ladder bar except for the rod ends.
But whatever, I'd rather have CalTracs than a ladder bar, at least they have some adjustment in them. You all can do what you like.
[Re: emarine01]
#1013239
06/15/11 05:42 PM
06/15/11 05:42 PM
dartman366
Mt. Vernon, Ohio
if I were to start a new project, I would definately go with a 4 link this time, I have had leaf springs under the car, then leaf's with floater's and ladderbars, then coilover's with ladderbars, each time was an upgrade for me, I have noticed that ladderbars are more violent in the initial launch, which on a marginal track can cause issues off the line,but most of the guy's that run 4 link systems seem to have less launch issues once the bars are set correctly,, I just think that 4 links will work in a broader range of track conditions before adjustments are needed. jmo
