shake down with the Dart
#1012919
06/13/11 10:46 PM
06/13/11 10:46 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
thrashed to get the car ready for the small tire race in Ky ran a shake down pass to make sure it went straight, trans shifted and i had brakes foot braked it pretty much from an idle, laid it down part throttle shifting @ 6,600 rpm and let out just before the stripe. 5.86 with a 1.32 60 and 114mph had a big smile on my face from that shake down pass it still had almost 250 more HP from the dyno sheets from what it made at 6,600 rpm now time to turn the thing up to lay a number down. we pulled back up to the staging lanes, i fired it up and put it in gear to pull out and i hear a tining noise ![](/ubbthreads/images/graemlins/eeek.gif) i shut it off as quick as i could we pulled it back to silverfishs pit, only place we had light to see what went wrong. i started pulling plugs out on the #1 side as Vic started pulling plugs on the other side. he got to #2 cylinder and the plug was smashed ![](/ubbthreads/images/graemlins/runaway.gif) pulled the valve cover and #2 cylinder had dropped a exhuast valve i pulled the head to see how bad it was need a new piston, lucky the cylinder wall doesnt have a scratch in it ![](/ubbthreads/images/graemlins/boogie.gif) head isnt hurt very bad also ![](/ubbthreads/images/graemlins/thumbs.gif) should be a easy fix ![](/ubbthreads/images/graemlins/hammer.gif) then its time to turn this beast up ![](/ubbthreads/images/graemlins/wave.gif) Bob
Re: shake down with the Dart
[Re: BobsProFab]
#1012926
06/13/11 10:56 PM
06/13/11 10:56 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
That sucks, Bob. This is a used bullet, right? I would treat the motor like any roller motor, and pretend it's at it's 250 pass maintainence check. New roller lifters, new bearings, hone, new rings, zyglow the crank and rods, valve job and new springs and keepers. And since one valve died, I sure as h e l l wouldn't reuse any of the remaining 15. That's how I see it. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: BobsProFab]
#1012933
06/13/11 11:29 PM
06/13/11 11:29 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Damn Bob. That sucks.
But I know you'll be back soon and better than ever.
BTW.......
I found that trans mount in my shed ![](/ubbthreads/images/graemlins/blush.gif)
[Re: BobsProFab]
#1012936
06/13/11 11:52 PM
06/13/11 11:52 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
this little 358 will eat that green turd for supper
Oh ha. Ha. Ha. Ha. Ha. Your car eats turds hahahahahaha
[Re: joshking440]
#1012937
06/14/11 12:06 AM
06/14/11 12:06 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Sorry,Bob,but I gotta agree with Josh on that one! Keith
