Re: Wilwood front Brake Drag?
[Re: Leigh]
#1011650
06/12/11 02:51 PM
06/12/11 02:51 PM
Quicktree
Shook my front teeth out. I expected them to have tighter tolerances than the $19 O'Reilly rotors.
did you call them? mine has never been bad enough to feel.
[Re: Quicktree]
#1011652
06/12/11 03:00 PM
06/12/11 03:00 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Oh yeah. The "tech" guy told me that they were stored "on end, that's why." He also told me the minimun spec was "as close as you feel comfortable with." There's some brilliance.
[Re: Quicktree]
#1011655
06/12/11 03:08 PM
06/12/11 03:08 PM
Posts: 197 New York
Dustin71
New York
keep in mind after the brakes have been applied it takes quite a few revolutions for the runout in the rotor to push the pads away from it. I think wilwood says like 10mph
Don't quite understand. The runout meaning the disc comes warped new? and the wobble in the disc returns the piston back off the disc? Then it will drag all the time i quess?
[Re: Dustin71]
#1011656
06/12/11 03:12 PM
06/12/11 03:12 PM
Quicktree
thats exactly how it works, you apply the brakes they close and the run out pushes them off the rotor. but it should not be as much as Leigh had. you shouldn't be able to feel it. you need to figure out what M/C you have. you could have one with built in residual pressure.
[Re: MR_P_BODY]
#1011660
06/12/11 04:36 PM
06/12/11 04:36 PM
Quicktree
I've never had any problems with my race slotted rotors
I have owned 4 different sets and never had a minutes problem. and worked on a bunch more over the years.
[Re: Quicktree]
#1011663
06/12/11 07:38 PM
06/12/11 07:38 PM
Posts: 2,521 PA
moparacer
PA
Well, I have only posted this about 20 times in the last year or so but my wilwoods were dragging bad and I rebuilt the calipers with the ROUND o-rings and they have been drag free ever since. If I bought a new set of wilwoods the first hing I would do is buy the round Orings and replace the flat ones that are in them. Quote:
The wilwood pads are very abrasive new,and making a dragging sound till you get them bedded good.
I also switched to the HAWK pads this week and cant belive how much better my car stops with them.
I was using the Wilwood E rated pads before and they were killing my rotors.
Hawk pads stop the car with half the pedal pressure.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#1011664
06/12/11 08:13 PM
06/12/11 08:13 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Moparacer is right. When I replaced my square o rings it took 160 psi of air to pop the pistons out..replaced with round and only 15 psi. I also put a compression spring between the calipers over the cotter pin to ensure complete retraction. But make sure there is no residual pressure in the system.
The little old lady from Pasadena is back!
[Re: Barnstorm]
#1011666
06/12/11 10:30 PM
06/12/11 10:30 PM
Thumperdart
State of confusion
Where does one get these o-rings?
[Re: Thumperdart]
#1011667
06/12/11 10:41 PM
06/12/11 10:41 PM
Barnstorm
Minnesota
Got mine from Wilwood. Told me I was nuts to put a round peg in a square hole.
