Ok how bout cat rockers?
#1011330
06/11/11 10:59 PM
06/11/11 10:59 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
Well ive got a deal cooking on a like new set of cat 1.6 rockers for a C note. I thought with my 325psi spring pressure and tight side Clearance for oil control...? I will change the adjusters to smith bros. I think ive seen guys have success with these with flat tappet cams
Re: Ok how bout cat rockers?
[Re: shoebox]
#1011331
06/11/11 11:29 PM
06/11/11 11:29 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Arent those stainless Non bushed? If so better watch anything tight on those rockers. Those have been know to Gaul IIRC.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: shoebox]
#1011333
06/11/11 11:51 PM
06/11/11 11:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your running 325 at seat on a flat tappet... I sure hope your talking open pressure
[Re: ahy]
#1011337
06/12/11 12:31 AM
06/12/11 12:31 AM
shoebox
mckinney texas
Id rather run the hyd and HD rockers too but no ones buying this good Solid i got so i guess im running it. I dont really want bearings On my rockers but the price is right. The car is a weekend toy anyway
[Re: Moparmal]
#1011338
06/12/11 12:54 AM
06/12/11 12:54 AM
Posts: 554 Kentucky
clovis
Kentucky
Mine have worked out fine so far. They have the same bearing as the Harland's (at least mine do). With that said I think it helps to pay attention to the shaft size. Harland uses an .875 shaft and when I found the specs on the bearing it is made for an .875 shaft. I run mine with Smith Bro adjusters and a hardened .875 shaft made from Thompson rod.
The ratio is off but at least they are consistent (1.7>1.655). They were also spot on for valve tip placement on my 906 heads.
I had a store credit with KMJ and took the money and bought some of the non bearing aluminum rockers and I have to say they do not look bad at all. I would still change out the adjusters. When I mocked them up they will require shorter pushrods, which they told me was some feed back they got on some of the sets they have sold. I bought them as I have in my mind at some point I may try the Comp .650 cam and with my 1.65 rockers my p2v clearance isn't going to happen.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: moparmanjames]
#1011347
06/12/11 11:03 PM
06/12/11 11:03 PM
Posts: 554 Kentucky
clovis
Kentucky
You can buy Thompson rod in an .875 od within an 1/8" of the correct length, which works fine. From there you just have to have them drilled (center, holddowns and oil). I tapped the ends and screwed in plugs. The Thompson rod was less than $50 to my door and less than $50 to have them drilled.
