Re: Ok how bout cat rockers? [Re: shoebox] #1011350
06/13/11 01:11 PM
06/13/11 01:11 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Re: Ok how bout cat rockers? [Re: Moparmal] #1011351
06/14/11 01:03 AM
06/14/11 01:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Go to Post #5 and work down....Ugly!!
http://www.moparnuts.com/forums/showthre...light=440source
The rockers pictured in that post are not the CAT stainless rocker arms. I have some CAT stainless rockers and they have bushings, and the body by the roller tip drops down to locate the valve stem. I have not used mine yet, but I was told the adjusters are not heat treated correctly? They came with stock looking stamped hold downs that could use some tweeking to get the rocker arms to locate over the valves better. I have some T&D hold downs and studs that I will probably use.
Re: Ok how bout cat rockers? [Re: 451Mopar] #1011352
06/14/11 01:54 AM
06/14/11 01:54 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
The guy who made that post seems adamant they are CAT - however another guy in the thread raises the same question you have (see below) - It may be that CAT have changed their design at some point?
The shape of the adjuster nose looks different then the 440Source ones too. Mine look meatier all the way around compared to the pics of your Cat ones. If mine somehow are Cat rockers, then it seems they may have made a 180 on their design engineering and quality control.
