Re: Does anyone see ANYTHING wrong with these PICS ?????
[Re: BILLYJAY]
#1010999
06/12/11 10:54 AM
06/12/11 10:54 AM
Posts: 2,177 ill
dennismopar73
ill
those are nice rods !! never seen an issue with them my self as well, as for the leak , i was looking at the carbon (black ) soot , on the rear of the gasket , may may not be what i see just looked funny compaired the the front also , the center pistons alfull clean , ?? have you discovered why ,, or did they get cleaned up ?? i could be wrong was it #v 5 rod bearing there looks like it got hot on the crank? never like to see this as i have several times allready, but but i do use for future education, if it was an oiling issue?? how do we , fix it and where was the issue located , and a cure, so we dont repeat i ask because we all need to know exspecialy if it an issue we all can look at an repaire before any more carnage thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BILLYJAY]
#1011001
06/12/11 11:09 AM
06/12/11 11:09 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
With all do repsect Billy, I highly doubt it was simply a "bad K1 rod". Hey, anything is possible I guess, but I'd be looking elsewhere. First off, unless you ( or the builder, not sure who did what in your build) can assure you: 1) The rod bolts were first cycled properly 2) The bores were checked before and AFTER cycling. 3) The rod bolt lengths were recorded before stretching AND after strecthing. ( not sure if you used torque and angle,torque or stretch) 4) Bores were checked for any chamfer or honing related impingments 5)Proper lube was used 6) Did you have a gasket leak and dosme hydro locking? 7) Did the valves hit the pistons FIRST, and beat out bearing to the point of failure? I will go on record to say that myself and quite a few other shops that share information have used hundreds of sets of K1 rods without issue, and in higher horsepower and higher RPM applictions, without ever an issue. When we see ANYONES rod or bearing failure, it is 99.9% of the time some other problem, or an installation error.Could a rod "just" fail? I suppose. Do they? Not really.The internet unfortunatly breeds a "mob" mentallity when things fail, and then a pile on effect takes place, often without qualified diagnosis, and the result is, " I got a bad brand XYZ" part. Most of the time, it is not the part. I think you really need to look at some other issues that may have caused this. That could involve many things such as already stated, oil starvation, improper set up/assembly and so forth. I did not do the work, so like everyone else, we are making assumptions based on your supplied information. I am simply stating, that in 25+ years of doing this, at many different levels, I would be shocked to see a K1, or any of the similar products just "fail". If the bearing spun, you very simply lost crush, or starved the bering to the point of friction tearing up the bearing sufrace, then the spinning begins. I would still spend some time investigating that area.I see this stuff all the time, nd can tell you, there is almost always reason.( often more information surfaces AFTER the fact...lol) Regardless, very sorry to hear, it really stinks for anyone. Step back, catch your breath and start looking at some of the things that you perhaps havent considered( or dont want to...lol) Best of luck to you. ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: BILLYJAY]
#1011003
06/12/11 11:20 AM
06/12/11 11:20 AM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
Well Todd.. i didnt say the K-1 rods failed.. if you REread my fisrt few post you will see where i think it was a bearing falure, not a rod failure, the issue i have with the rod is that it took out the side of my block....lol...i can assure you that the man(cousin Tony) who screwed this motor together is one of those guys who irratates me to death with the "Details" of motor building..he checks,rechecks and double checks everything.. drives my crazy everytime we build a motor.. but in the past 25+ years of motor building, this is the first one that has has ANY ISSUES.. never even lost a bearing,pushrods or anything else until this motor..the reason for thr K-1 comments was another member here had sent me an email telling me that he had the same thing happen to his motor and wanted to know what happened to see if there was any common factors... So, looks like i will be looking to have someone repair my indy block in the near future..anyone knows who does the best work when it comes to repair of Alum block... Indy,I know... ![](/ubbthreads/images/graemlins/rant.gif)
[Re: BILLYJAY]
#1011004
06/12/11 11:34 AM
06/12/11 11:34 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You may or may not have over-reved the engine.
But, look at the exhaust valve marks in the piston. Bet the bearing was getting a hard lick too due to the hammering taking place at the piston with the valve beating into the pistons.
Think about this the exhaust valve and piston are running towards each other. Really hard lick. The bearing takes a lot of abuse from this. Finally the rod breaks and you got a bigger mess.
At least you are running an alluminum block. It can be fixed pretty quickly.
Finding out why you have collisions going on in your engine may take a while longer.
Leon
[Re: Leon441]
#1011007
06/12/11 11:50 AM
06/12/11 11:50 AM
Quicktree
Leon
I thought I seen a little valve mark on the piston but wasn't sure. ![](/ubbthreads/images/graemlins/iagree.gif)
[Re: 408Dust]
#1011008
06/12/11 11:51 AM
06/12/11 11:51 AM
Posts: 16,934 NC
440Jim
NC
Valve hitting piston removing oil film. Bearing gets damaged resulting in broken rod. Just a guess until motor is disassembled.
It does look from the one and only picture that some exhaust valves hit the pistons. But the broken rod could have caused the #3 valve mark, and the lash cap jamming the #1 open could have caused that. I can't tell.
I wouldn't blame the rod right now, but it needs more investigation to figure out what caused the chain of events.
[Re: Quicktree]
#1011009
06/12/11 11:54 AM
06/12/11 11:54 AM
Posts: 739 Florida
408Dust
Leon
Quicktree you need some...
[Re: BILLYJAY]
#1011010
06/12/11 11:54 AM
06/12/11 11:54 AM
CompWedgeEngines
Syracuse,NY
I just re-read that and saw what you posted. I originally thought you were blaming the rod. I am glad your engines guy drives you nuts, that what we do... ![](/ubbthreads/images/graemlins/laugh2.gif) ...he will have his input, thats for sure. Like mentioned, its aluminum, and cn be easily fixed. At least there is a little bit of sunshine in this...still hope you get it handled and just move forward. ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: 408Dust]
#1011011
06/12/11 11:56 AM
06/12/11 11:56 AM
Quicktree
Leon
i know it's hell getting old
[Re: BILLYJAY]
#1011015
06/12/11 08:35 PM
06/12/11 08:35 PM
Posts: 16,934 NC
440Jim
NC
Yea, im guessing that the lash cap jamming the valve into the piston helped the bearing failure and then the rod to break...
I thought the flying lash cap was on #1 and #3 was the one that broke? I guess the cap could have found its way over to #3, but without any marks to support it, that is unlikely. But it could have jammed #1 causing the mark on that piston.
