Re: CNC port for W8
[Re: W5DART66]
#1010146
06/09/11 10:27 PM
06/09/11 10:27 PM
Posts: 1,784 PA
W5DART66
PA
Re: CNC port for W8
[Re: LA360]
#1010149
06/09/11 11:46 PM
06/09/11 11:46 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Where is the little graemlin with the guy pokeing the red X ?
Re: CNC port for W8
[Re: W5DART66]
#1010153
06/09/11 11:56 PM
06/09/11 11:56 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I can see the pics fine Brett.
What would be the cost to upgrade a set of Coleman/Arrington W8's.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Re: CNC port for W8
[Re: MR_P_BODY]
#1010156
06/10/11 02:19 PM
06/10/11 02:19 PM
Posts: 1,784 PA
W5DART66
PA
Re: CNC port for W8
[Re: 408strokerdart]
#1010160
06/10/11 04:58 PM
06/10/11 04:58 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
looks nice,,, what i would reccomend is to measure bolt column heights, valve cover rail to deck dimension, valve depth off deck, all off your model so you can make sure guys dont send you angle milled heads,, or heads that havent been milled,, or milled more,, and if you cut your std program the port wont be in the correct location
Re: CNC port for W8
[Re: W5DART66]
#1010161
06/10/11 08:23 PM
06/10/11 08:23 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Those numbers are much higher than what my W8's flowed on Compuflo's bench. Dont want to recut existing heads, dont know who did them. Have raw Zuess castings needing done eventually. also not running big cubes, may be too much for me. What those numbers relate to as far as cubes and RPM ? Look nice.
Re: CNC port for W8
[Re: theclutcher]
#1010163
06/10/11 09:15 PM
06/10/11 09:15 PM
Posts: 1,784 PA
W5DART66
PA
Your heads look like colemans stuff are they 7mm 5/16 guide? The heads I just did are for Big RPM 360CI or fast bracket big CI. The test bed will be 2 engines one in car right now and my 2011 engine master deal.
