Re: Build me a 1000HP 400ci NA engine...........
[Re: Spode]
#1009524
06/09/11 05:23 PM
06/09/11 05:23 PM
Posts: 1,019 Finland
mafo
Finland
well now you did it, here I was pleased with my w8 s anyone knows what price range those are in? I have seen a couple of R4 blocks for sale lately but I don t think you can stuff 400 inches into one of those, maybe there still are R3 blocks available without lifter bores
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1009525
06/09/11 05:32 PM
06/09/11 05:32 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
If the XR blocks can be had blank, it may be possible to build a nice BIG P-5.
[Re: jim sciortino]
#1009526
06/09/11 06:05 PM
06/09/11 06:05 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I have a 416 inch R3 W8 small block for sale that is 1000 hp with cast manifold and single carb and it is for sale..save somebody abunch of money..I hate to sell it,but I have know use for it around my area and especially when the Milan boys are running 8.0's these days kinda worthless to compete anymore with those guys..
If anybody is interested let me know,make someone a heck of a deal.
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: fishy340]
#1009528
06/09/11 08:14 PM
06/09/11 08:14 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
the mbe heads are the aussy ones, they are very thin around the intake port,, and everyone has issues with them cracking in the bowls,, also the guy from australia doesnt want to sell them to the us anymore cause he is afraid of lawsuits
i dynoed a motor that bes had done and it was down 60hp from what they said,, dyno's are tools
everyone throws around numbers but to run fast in a/sma at about 2900lbs,, 420 inch motor,, 7.80's-7.90's would take about an honest 1000hp at 2000 ft air
[Re: moderncylinder]
#1009529
06/10/11 12:08 AM
06/10/11 12:08 AM
Posts: 6,151 Melbourne , Australia
LA360
The Aussie P5's are an exact copy of the Mopar P5 head, right down to the part/casting number from what I have been told. They even copied the cracks is one remark I have heard thrown around. An R4 block will take 400ci, Aussie Pro Stock have been doing it for years. I doubt that Mopar will get back into making them, Unless Chrysler Australia make a push for them to be produced again. The Mopar backed car over here has their engines done by Rick Watters nowadays, perhaps pick up the phone and have a chat with him.
Alan Jones
#1009531
06/10/11 10:02 AM
06/10/11 10:02 AM
jim sciortino
Trumbull,CT.
That is a shame....
After all this time and a completely different supplier, the cracking issues STILL haven't been addressed.
I doubt this would be allowed to happen in the world of SBX and Little Chief heads.
[Re: jim sciortino]
#1009532
06/10/11 11:08 AM
06/10/11 11:08 AM
mafo
Finland
Maybe it s time for Alan to step up and make a billet P5 head , I can test the first pair for free...
[Re: moparniac]
#1009534
06/10/11 02:41 PM
06/10/11 02:41 PM
moderncylinder
detroit area
rick watters has a set of the newer aussie heads and they are sprinklers as well,,,, there is no metal in the bowl area
i was going to have them cast here in the us with no labels or markings, then make plastic pieces which receive in where the labels and markings need to be
it would prob be 5k for a set of castings,, not enough demand,, so started thinking of a small inch 99 hemi
what matters is the timeslip,, not the dyno number,, guys say you loose 2 tenths and some mph going to a 10.5 tire,, i dont believe that if you can still go 1.17 or so 60 ft
#1009535
06/10/11 06:38 PM
06/10/11 06:38 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Hey Jeff, with the small cube Hemi99 motor, what type of bore/stroke do you feel would work. I'm assuming Pro Stock uses between 4.60 and 4.7 bores so that would put the stroker roughly around 3.09 or so.
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#1009536
06/10/11 07:13 PM
06/10/11 07:13 PM
moderncylinder
detroit area
i was thinking of using a 4.440 or a 4.500 bore,, ive done some hemi 99 pro stock before and it didnt seem to mind a smaller bore on the intake air flow,,, if the valve notches were far off the bore to allow a good ring placement,, id run a reasonably small bore to get a 3.25 or 3.30 stroke atleast
the motor i was thinking of building was going to be about 460 inches,, morgan had built one for comp that his son was supposed to race,, which he said he ran it higher and it was down about 65hp from a 500 inch motor,, he ran 6.99 with it at 2350lbs at columbus about 5 years ago in b/a
i could run a 4.500 bore with a typical pro stock crank of 3.625 stroke and get 461 inches,, my car would be about 3200lbs in a/sma,,, id need to make about 1200hp to be real fast,, with it being a wet sump,, you could just get a used pro stock motor and sleeve it down then get new pistons,, though i know from experience that in a motor like that the sleeves will move around alot
[Re: mafo]
#1009537
06/10/11 08:15 PM
06/10/11 08:15 PM
LA360
I have had it in the back of my mind but I really don't have the coin for the rest of the engine! As Jeff also pointed out, the demand would be pretty low and it would really be a labour of love. I don't have a casting lying around to get 3D scanned, and I would really have to work in with someone like Jeff, or MBE or CFE or CFD to get the ports and rocker geometry correct etc. There are four cars in Aussie Pro Stock running P5's currently, plus buyers in the US. I guess the other thing is if they took off I doubt I could keep up with the demand, I do my best work after hours, lol. It's been a dream of mine for sure
Alan Jones
#1009538
06/10/11 08:53 PM
06/10/11 08:53 PM
Posts: 614 Michigan
Get-X
Wow, I'm surprized that it only fell off 65 hp with the small bore. You would think valve shrouding would be a big deal? I wonder if they had to use a different cam profile?
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: PETE@BESTMACHINE]
#1009540
06/10/11 11:00 PM
06/10/11 11:00 PM
moderncylinder
detroit area
when i seen larry run 6.99 or whatever it was it was with a small motor that he had done,, i was told 470 or so,, i heard other details from jeff taylor and joe tueton as they were talking to larry about it all
the heads i did for morgan flowed 570,, i flowed them on as small as a 4.500 bore and the flow did not go down much at all as i recall,, though was a few years ago that i did them
i think you can run a bore as small as 4.500 and get it to fit,, ill have to look at it again,, but im pretty sure,,, you dont need a 2.550 intake valve to feed the smaller motor,, so you could go 2.450 and still get 540 probably,, that in itself would let you run a smaller bore,,, the exh might need to be moved off the cylinder wall for a smaller bore,,, which could be done
[Re: Adrielp]
#1009542
06/13/11 01:18 PM
06/13/11 01:18 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Indy 440-1 or B-1 heads, mechanical fuel injection, 11:1 compression, 8 amp mag.set at 50 degrees advance, 75% in the tank, 1000+ hp. Hope it's an open wheel car, cause nitro in a door car will bring tears to your eyes and burn your nose like there's no tomarrow!
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
#2622616
02/17/19 05:47 PM
02/17/19 05:47 PM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
what matters is the timeslip,, not the dyno number,, guys say you loose 2 tenths and some mph going to a 10.5 tire,, i dont believe that if you can still go 1.17 or so 60 ft please empty your pm box
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
