Page 2 of 4 1 2 3 4
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009504
06/09/11 11:39 AM
06/09/11 11:39 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Anything is possible, provided you have the money and intestinal fortitude to see it through. IMO biggest bore you can tolerate(aftermarket block)and stroke to get you where you need to be. Be prepared to by valvtrain pieces from time to time as you are gonna need to see A LOT of RPM to make it happen. Gonna need the bore size to unshroud the valve.
IMO a SMALLBLOCK of those cubes may be a MUCH better way to go. The BB heads out there are not built to make power with the small bore you are asking about. Kinda why the guys at the top of the aforementioned classes are running smallblocks not bb....Just my
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009505
06/09/11 12:08 PM
06/09/11 12:08 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If you use the theory of 2hp/cfm head flow, you need heads that flow 500 cfm, and a 400cid engine would have to spin around 12,000+ RPM.
Assuming a race block with 4.5" bore and 3.15" stroke (400.79 cid), 12,000 RPM, and a rod ratio of 2:1 The piston speed will be 6,300 fps, and piston acceleration will be 259,022 fps^2.
I think the above calculations are with a "normal" compression ratio of around 10-11:1.
If you push the compression ratio up to around 15:1+ you should hit the number with slightly less head CFM and engine RPM?
With the High piston speeds getting the rings to keep sealed will be a problem, need gas ported pistons and crankcase vacuum system, drysump oiling, etc, pretty much prostock type engine.
Re: Build me a 1000HP 400ci NA engine........... [Re: 451Mopar] #1009506
06/09/11 12:16 PM
06/09/11 12:16 PM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
Don't the world of outlaw sprints make about 950hp at 410ci? Granted that's injected on alky but also built to take alot more abuse then a drag engine. So maybe take a look at what they are doing.
Re: Build me a 1000HP 400ci NA engine........... [Re: Brandon70cuda] #1009507
06/09/11 12:39 PM
06/09/11 12:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
To make it live you want the longest rod you can find, less rod angle pushing the piston into the cylinder wall and a lighter piston/rotateing assembly, plus it helps to NOT rip the pin out of the piston as acceleration forces are smoothed out. Find an early 230 casting block, get is sonic tested and use aluminum main caps and mabey even aluminum rods to absorb shock to the block, a good main cap girdle and tall fill of hard block and REALLY QUALITY machine work is about all you can hope for to make a stock block last a little while. Just have the deck squared up not milled a ton, that extra meat will help head gasket seal and block torsional rigidity, you don't have much to start with so don't squander what you do got. To keep the valves from floating you should probably invest in titanium pushrods, retainers and valves, lightest lifters you can find (solid roller of course) and replace your springs every so often. Get one of the good head guys to build you a set of heads custom for this thing, mabey some preadators and have the valves moved a tad to help air flow with the smallish bore. Run as much compression as you fuel will allow.
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009508
06/09/11 01:04 PM
06/09/11 01:04 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Can be done. 426 guys make 900 -1000 with stock heads.
STOCK ???
stock casting then maybe 10k in work . welded and rasied exhaust ports plus rehsped intake ports
home of the
Sox and Martin Hemi Duster
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009509
06/09/11 01:45 PM
06/09/11 01:45 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Can be done. 426 guys make 900 -1000 with stock heads. Are Preddys better than S/S hemi heads?
They're about the same at around 480 cfm. But SS/AH heads need to retain stock valve angles and valve sizes!
This post is available in double vision where drunk.
Re: Build me a 1000HP 400ci NA engine........... [Re: bwdst6] #1009510
06/09/11 01:53 PM
06/09/11 01:53 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Then there's the small chambered Stage V Millennium Hemi heads that will flow 530
home of the
Re: Build me a 1000HP 400ci NA engine........... [Re: HEMIFRED] #1009511
06/09/11 01:56 PM
06/09/11 01:56 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
as others have said, longest rod possible to keep piston velocity down...the best tq/CID ratio I've seen is 1.4-1.5 lb-ft per CID, so at 400 cubes, you're looking at 560-600 lb-ft max. which means you'll be ~9-10k RPM to hit 1000HP with peak torque happening up there.
sounds like basically you'd need to take a winston cup motor, scale it up 15% to 400 cubes, and then a little more....they're making ~850HP from 355 cubes, IIRC....
probably B1 PSO heads would be your best bet for a big block, maxed out W9 raised port for a small block? wonder how much you could coax from a 6.4L genIII hemi, if you could come up with a valvetrain stable to 10k RPM?
2017 Grand Cherokee Overland
Re: Build me a 1000HP 400ci NA engine........... [Re: HEMIFRED] #1009512
06/09/11 02:00 PM
06/09/11 02:00 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Fred, do you recall what the 383 hemi P/S guys were making back in the day?
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009513
06/09/11 02:23 PM
06/09/11 02:23 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
DAVE HEITZ just did one last year for one of Reed's cars. Dave built the roriginal record holder for John Hagen . I beieve just over 800 HP
I don't remeber where I got this info but it's informative
Back before NHRA had a policy of all Pro Stockers being 500 CI / 2350
pounds, they used to factor different engine at varying
weight-to-cubic inch ratios in that class, assigning whatever figure
they thought would make for competitive racing. Because of heavy
pistons and difficulty in getting the requisite 15:1 compression,
Hemi's had fallen out of favor. Some people tried de-stroking a 426
to 383 cubes, but it didn't work well, exacerbating the compression
ratio problem, as well.
One of my closest friends at that time (1981) was a racer who looked
at the problem and decided to attempt to add the 426 Hemi heads to a
383 block, The 383 was lighter, had a shorter stroke, and a better
rod angle (in his opinion), using shorter, lighter connecting rods.
He eventually built 10 of these blocks, which were 400 CI blocks (he
said the casting cores for the 400's had more meat in the cylinder
walls, determined after sonic testing a bunch of 383/400 specimens.)
One of these blocks ended up in the late John Hagen's Plymouth Arrow
Pro Stocker and without any factory help, nor more than a few months
development time, set the mph record for Pro Stock. The car also was
runner-up to Lee Shepard at the Pomona World Finals that year, the
last race before the 500-inch/2350-pounds for everyone rule went into
effect the following year.
How fast might this combination have been given an ounce of factory
help, or a couple of year's development time???? VERY fast, I'd say.
The modifications to the block were covered in detail in an article I
wrote for Super Stock and Drag Illustrated in the June 1980 issue.
There are lots of photos to document the addition of the row of
hold-down bosses to the valley area, and the machine-work and welding
in of half-tubes to enable the push rods to lay down the required
angle to connect with the exhaust valve rocker arm pushrod sockets.
It was a job for a welder who could weld cast iron to steel and not
have it crack at the seam, due to thermal expansion/contraction.
One of these engines went into an A/Dragster and promptly grabbed the
record for that class (a Canadian, named Wally Dyck.)
Some were sold to high-line Mopar guys like Butch Leal; I think Dick
Landy may have ended up with one. I know that Charlie put a 440
crank in one and ran nitrous to it in a Volare he built for IHRA Pro
Stock.
I also wrote a follow-up article about the accomplishments of that
engine for Chrysler Power magazine a couple of years back, but I
can't remember which issue, offhand.
At any rate, the whole deal was about specific output, and the 383
has it all over the 426 and 440 when it comes to that, because it's
moving a smaller amount of air through the same (Hemi) valves and
ports, enjoying less friction, a shorter stroke, higher redline, and
less reciprocating weight along the way.
Charlie did a lot of research on welding techniques before he came up
with a successful rod and heat combination in order to make welds on
the block that didn't crack in competition, but he finally got it.
I think he was selling these things for a thousand dollars apiece; a
pittance, considering all the work involved.
I think he also added an oil return line from the heads to the pan,
as the Hemi had no oil return that would work with the low-
home of the
Re: Build me a 1000HP 400ci NA engine........... [Re: RemCharger] #1009514
06/09/11 02:46 PM
06/09/11 02:46 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
There are number of heads (both big & small block) that will support 1000hp @400ci in serious effort N/A builds......but, any particular reason for a stock 400 block???
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009515
06/09/11 02:54 PM
06/09/11 02:54 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Not enough CI for predator heads IMO. Fully ported B1's and spin it to 9500. Ask Bob Mazzollini, he did it.
No offense to Bob Mazzollini, but he either doesn't run his car hard or he just doesn't make competitive power because when it comes to SS/AS, there's two other mopar guys that own that class that I could look to for help. One is the record holder and the other is the former record holder(Wes Lepold Jr and George Vignogna Jr. Both run SBM around 390's though.
Yeah, I'm not sure what class he used to run it in, but I thought he said comp. And it was several years ago even before PSO's and M/C's. He knows how to make power and is a good guy and may not have the $$$$some have, but he has the knowledge. Up to you. And I agree, the block expectent life cycle won't be good,
Re: Build me a 1000HP 400ci NA engine........... [Re: Adrielp] #1009516
06/09/11 03:08 PM
06/09/11 03:08 PM
detroit area
moderncylinder Offline
detroit area
you cannot use a predator head,, and you cannot use a millenium head or any stage v head for that matter
if you want to run ss/am, or a/sma,, you need to run parts with numbers from mopar
a/sm and ss/am stuff that are fast are small blocks,, but i dont think you can get there with a small block without alot of money,,, the p-5 hemi is dead since there are no "new" available head castings
your best bet is to get a hemi 99 and destroke it some,, run it like that then build a new one with a small bore,, and build a 420 inch motor or so
if youre serious about this i may build one over fall/winter,, i can share ideas with you if you are doing one too
lloyd wofford has a b/sma stratus that has a patterson 358 p-5 hemi in it,, it make 950 or so and runs about .45 under,,, since there are no parts available to build a "better" motor,, there are thoughts to build a hemi 99 around 400 inches for it,, and move to a/sma
jeff
Re: Build me a 1000HP 400ci NA engine........... [Re: moderncylinder] #1009517
06/09/11 03:12 PM
06/09/11 03:12 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
VERY SIMPLE TYPE SGE RACE CARS ON GOOGLE,and theres a guge article about Scott Gove's 7 sec 1000hp r4 w8 motor there!
Re: Build me a 1000HP 400ci NA engine........... [Re: fishy340] #1009518
06/09/11 03:14 PM
06/09/11 03:14 PM
detroit area
detroit area
scott gove's w-8 motor was actually sold by stancil to scott,, it made less that the p-5,, i think like 920 hp
scott runs 7.90's in great air,, in the same air lloyd runs 8.0's about 200lbs heavier
Re: Build me a 1000HP 400ci NA engine........... [Re: moderncylinder] #1009519
06/09/11 03:18 PM
06/09/11 03:18 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
o yea when u get to the web page on top where it says news,u can read about 7 sec 358 ci 1000hp
Re: Build me a 1000HP 400ci NA engine........... [Re: fishy340] #1009520
06/09/11 03:21 PM
06/09/11 03:21 PM
detroit area
detroit area
well it doesnt take 1000hp with a clutchless 5 spd to run 7.90's in a 2700lb car,,, takes about 900 which is about what it makes
if you want to run a/sma and be good,, you need a hemi 99,, a small block mopar wont do it
... i went and looked at scott's site and seen nothing about him making 1000hp....
Re: Build me a 1000HP 400ci NA engine........... [Re: moderncylinder] #1009521
06/09/11 03:45 PM
06/09/11 03:45 PM
Trumbull,CT.
Trumbull,CT.
jeff
Jeff, MBE has ads for P-5 stuff on their site. Maybe the castings are from down-under.
Re: Build me a 1000HP 400ci NA engine........... [Re: moderncylinder] #1009522
06/09/11 04:16 PM
06/09/11 04:16 PM
Arkansas
Adrielp Offline OP
Adrielp  Offline OP
Arkansas
jeff
Jeff I was worried about that cause I know that NHRA specifies approved heads but I forgot about the fact that it must be an OEM released cylinder head. That really puts quite a downer on my plans. We have tons of spare 400 parts and things but no hemi 99 stuff whatsoever. I am serious when I say I want to build SS/AM car and transition it towards A/SMA, I just don't know if it will be a big block anymore. On the other hand, the technology should advance quite a bit before I get the chance to build it. Like I said, this is research and learning for me. I have to get my degrees first and the knowledge of engine building I will have leaving grad school will be much more significant then, alotting me a little more opportunity to do more building than paying to build hopefully.
Adriel Paradise
Substation Design Engineer III
Re: Build me a 1000HP 400ci NA engine........... [Re: jim sciortino] #1009523
06/09/11 05:00 PM
06/09/11 05:00 PM
Upland, California
Spode Offline
Spode  Offline
Upland, California
jeff
Details
MBE’s P5 Dodge Hemi is a great example of an engineering exercise taken to the extreme. The Hemi is are already famous for great power production, but MBE has created a next-generation design that combines the raw power production of the classic with the latest advancements in induction theory to create what MBE owner Matt Bieneman calls, “the most efficient cylinder head that we sell, period.”
The P5 Hemi utilizes every trick in MBE’s extensive book to create incredible flow potential. This head features valve angles that MBE keeps confidential, and when equipped with Jesel’s rocker arms designed especially for this head the pushrods angles are perfectly straight. The chambers can be sized anywhere between 25 and 45 cc’s and are cut to accept 2.280 intake and 1.600 inch exhaust valves.
When you combine all of those factors with MBE’s top-of-the-line ports, the result is a jaw-dropping ability to deliver air and fuel into the combustion chambers. We’re talking about 460 cfm through the intake ports and 287 out the exhausts! And remember, MBE is the only induction specialist in the industry willing to guarantee its advertised flow numbers.
This is the cylinder head that helped Comp Eliminator racer John Edwards set E.T. and mph records. The ability to flow big numbers means this head will really separate itself from the competition as the rpm’s climb higher. On the engine dyno, it has been used to produce a proven 1,100 horsepower on a naturally aspirated 395 cubic inch engine at 10,000 rpm. This cylinder head is a great option for any race engine between 340 and 460 cubic inches, especially if your goal is an engine that keeps making power at rpm levels the competition has long declared to be “past the redline.”
Page 2 of 4 1 2 3 4
