Re: LED equivalents for our filament bulbs
[Re: Pyper70]
#1008403
06/11/11 08:20 AM
06/11/11 08:20 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I have some drop in "194's" I got off Ebay that worked pretty good in my dash (74 Duster) Price was dirt cheap too. The only thing I note is the LED's pick up the blue tint of the factory coloring on the inside of the cluster. When I have some free time I was going to experiment with a spare cluster with either white or silver paint. With 194's the cluster was too dim, higher wattage bulbs were great but the headlamp switch got burning hot. http://cgi.ebay.com/2x-SUPER-WHITE-T10-7...=item3cb8d6fc0eI also tried the bulbs with a single lens, they don't seem to work as well as these.
[Re: gdonovan]
#1008404
06/11/11 01:07 PM
06/11/11 01:07 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
These are the ones I used in my dash. I wanted these because you want to throw the light around the cluster to illuminate everything. Having 5 LEDs pointing at the driver will cause the focal beam to be very direct instead of a broad dispersal. http://cgi.ebay.com/ebaymotors/2pcs-HID-...sQ5fAccessories
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: hemi68charger]
#1008405
06/11/11 03:16 PM
06/11/11 03:16 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I am wanting to change the clearance lights on my dually with LED's. @ $12 a pop!
Less amperage on the already weak electrical system in my '93.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#1008406
06/11/11 10:30 PM
06/11/11 10:30 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I have the cylindrical type LED's on the rear of my '68 B'cuda, and they work great, look great. I think the key is having a small tail light. The lense is about the size of a deck of cards, and the LED light completely fills the lense. Older mopars with round or small tail lights should benefit, where the large tail light assemblies are more difficult to get the right look.
I could not get LED's to work on the front signals on the same car. I suspect it may be something to do with the hood mounted signal indicators also in that circuit that are still incandecent.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1008407
06/12/11 12:54 AM
06/12/11 12:54 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The problem with the turn signals is that they're wired in series. LEDs have a fixed positive and negative terminal. You can't run them positive to negative like the turn signals in out older cars.
[Re: feets]
#1008408
06/12/11 02:13 PM
06/12/11 02:13 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
just an FYI to anyone replacing the stock flasher for one that's compatible with LED's. If the signals don't flash, reverse the wires that connect to the flasher. That solved my issue when I put LED's on the rear of my charger. I think the reason is what Feets said above.
I also had temporarily put LED's in the front of the same car and they worked fine with the hood mounted turn signals still having stock bulbs. You can mix them and if you're doing just front or just rear, you should get away with the stock flasher...I did.
[Re: hemi68charger]
#1008409
04/16/12 04:25 AM
04/16/12 04:25 AM
Posts: 2 america
2341
america
Anyone sell or know of a good online site that sell the LED equivalent to our most popular OEM filament bulbs? I'm looking to replace the original filaments with LED's.mini led light bars Apparently they operate brighter and cooler? flexible led strip lighting I'm restoring my complete instrument cluster on the Daytona and wish to upgrade along with other locations like the center console, dome light and possibly the running/brake lights.led outdoor lighting fixtures The later only if I don't get that multi-point light source look. Types I'm more interested in: 57 158 1004 console courtesy light (89?)
Thanks in advance.
[Re: 2341]
#1008410
04/16/12 03:42 PM
04/16/12 03:42 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I just got my WLED-RHP6-AC in red from www.superbrightleds.com for my 81 shorty. These are dimmable with your normal dimmer switch and they are 360 lights. I going to use them in the speedo and gauge receptacles. Im also going to line the housing with reflective tape. Theres a good post with pics on RCC about them. ![](/ubbthreads/images/graemlins/thumbs.gif)
I am truckless..
