LED equivalents for our filament bulbs #1008382
06/07/11 08:42 AM
06/07/11 08:42 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Anyone sell or know of a good online site that sell the LED equivalent to our most popular OEM filament bulbs? I'm looking to replace the original filaments with LED's. Apparently they operate brighter and cooler? I'm restoring my complete instrument cluster on the Daytona and wish to upgrade along with other locations like the center console, dome light and possibly the running/brake lights. The later only if I don't get that multi-point light source look.
Types I'm more interested in:
57
158
1004
console courtesy light (89?)
Thanks in advance.
Troy
Houston Mopar Connection Club
Re: LED equivalents for our filament bulbs [Re: hemi68charger] #1008383
06/07/11 08:59 AM
06/07/11 08:59 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
If you do stop and turn signals you'll need to add resistors or replace the flasher with one that works with LED's
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: LED equivalents for our filament bulbs [Re: Savoy1964] #1008384
06/07/11 09:07 AM
06/07/11 09:07 AM
Houston, Tx
Houston, Tx
Heard this was the flasher you're speaking of?
Bussmann NO.232 20 Amp Round Heavy-Duty Electronic Flasher
Troy
Re: LED equivalents for our filament bulbs [Re: hemi68charger] #1008385
06/07/11 07:25 PM
06/07/11 07:25 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Guy at work has been buying from this co. and turned me on to their site.
http://www.superbrightleds.com/cgi-bin/s...brake-turn.html
You will need to buy the same color LED as the lens. If you use white LED's reds lens will look pink and amber lens will look almost white.
Re: LED equivalents for our filament bulbs [Re: hemi68charger] #1008386
06/07/11 11:17 PM
06/07/11 11:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I've tried to replace incandescents with LED's many times with little success...mostly on motorcycles (for the obvious benefits of less power, brighter light and longer bulb life) but I've come to the conclusion that it doesn't work very well.
the short answer is that the LED's are aimed in one direction and the incandescent bulbs are omnidirectional. light fixtures and housings that were designed for incandenscents don't work properly with LED's. The only retrofit stuff that seems to work at all are panels made for a specific application that fit into the old light housings. The replacement 1156 etc. led's were garbage....got a drawer full of them.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: LED equivalents for our filament bulbs [Re: DPelletier] #1008387
06/07/11 11:33 PM
06/07/11 11:33 PM
Houston, Tx
Houston, Tx
I was gearing more so to the dash lights... Being that they are confined to a closed area with light being back-scattered, I would think they would do the same job.
Troy
Re: LED equivalents for our filament bulbs [Re: hemi68charger] #1008388
06/08/11 09:19 AM
06/08/11 09:19 AM
DPelletier Offline
DPelletier  Offline
well, i have my doubts but it would be nice to have cool lights that take much less power and last forever. let us know if you try it.
Re: LED equivalents for our filament bulbs [Re: DPelletier] #1008389
06/09/11 10:29 AM
06/09/11 10:29 AM
Houston, Tx
Houston, Tx
I'll probably get the bulbs. I have a setup such that I can turn on the lights with the dash on the bench to test it in the dark to see what it would look like prior to installation. Wish there was just a convenient place here locally to run in and get the bulbs instead of having to get them online and wait for shipment.. Oh well......
Troy
Re: LED equivalents for our filament bulbs [Re: hemi68charger] #1008390
06/09/11 03:12 PM
06/09/11 03:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Take a look at this thread: http://www.dieseltruckresource.com/dev/showthread.php?t=209884
I did the exact same thing to my instrument panel. It's an amazing difference! Cheap too. Best of all, the lights still dim like the stock stuff did.
I plan on converting some exterior lights to LED. If you do that you MUST get LEDs the same color as the lens. Be sure you get LEDs with a wide lighting angle.
My LEDs came from superbrightleds.com.
- Stu Harmon
Re: LED equivalents for our filament bulbs [Re: feets] #1008391
06/09/11 03:54 PM
06/09/11 03:54 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Don't waste your time on the LED replacements for your tail light housings. I did and it was a waste of cash. The "36" LEDs they advertise aren't as bright. I went ahead and did my drivers side with White PCBs and it looks pretty good. I have two 36 LED flat arrays in each slot on my Charger. They are the 1157 replacements, use three wires to achieve the Hi-Lo you want for Brake/Turn. I had to change the system to an electronic Flasher. OI havent done the Passenger side yet but the left bank has 216 LEDs pointing at the driver behind you. Since there was a shadow to the left and right of the arrays I have since upgraded and made use of the 36 Red LED Bayonets that didn't work bright enough in the first place. I now have those in front of the PCB arrays and they fill up the rest of the slot with the red glow. So really between PCBs and the Bayonets...I have 324 LEDs on the drivers side. I have a video on Youtube showing my car with them installed, the period of time between stepping on the brake and the lighting of the brake lights is almost 1/2 second apart.
I swapped over my license plate light, my reverse lights to hyper white, my front turn signals to Amber, I also hanged over my dash lights to an LED and the cluster looks like a baby blue. The LEDs on the cluster have one on each side and one facing on the tip. (5 LEDs total) I like it....but you can't dim them. I put them on bright and leave it there anyways. Have to find the bulbs for my hood turn signals, the console courtesy lights, the dome light, trunk light, and map light...but everything else works just fine...
I dunno how to do the full screen on YT but here is the video
http://www.youtube.com/watch?v=2Rz7NTJtL2o
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: LED equivalents for our filament bulbs [Re: feets] #1008392
06/09/11 04:21 PM
06/09/11 04:21 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Did just about all of them on the RR, most on the Toyota Supra (86.5 MY), and a few on the wife's Acura Vigor, none on the Durango.
Experimented with a lot of different vendors, mostly on eBay and Superbrightleds.com. Lots of different styles of replacement "bulbs".
The ones that work best have at least one - usually 3 or so - set of radially aimed LED elements. For better dispersion within the lens housing and to reduce the 'points of light' effect. The bulbs work best when the socket has them aiming directly forward or rearward, with lots of radial light for dispersion within the housing. Hopefully, the reflector in the housing is in good shape.
They'll work acceptably when the bulb axis is aimed straight to one side or other (as in the Toyota), or vertically, AND the reflector behind it is good shape, AND the bulb has lots of radial elements. Hence in the Toyota, they're only in brake lights, front turn signals, and side markers in the Toyota, but not in the rear turn signals or front parking lights.
They'll work poorly when the bulb is aimed at some goofy angle or other. Hence in the Acura, they're only in front side markers (the previous 194 bulbs seem like they failed at a rate of 1 a month, so for that reason alone the LEDs are an improvement) and front turn signals.
One last thing about the 1157 or 1156 replacements is about size. Typically the 'glass' portion of an incandescent bulb is conical as it nears the base. Many LED replacements have the "bulb" portion cylindrical in shape. If your car has deep sockets for bulbs, some LED replacements may not fit, as the LED array will hit the lens housing or socket housing before the bulb bottoms in the socket. I had that happen with a few vendors' products. IIRC, superbrightleds products fit with a smidgeon of room to spare.
Re: LED equivalents for our filament bulbs [Re: Pyper70] #1008393
06/09/11 05:39 PM
06/09/11 05:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Pyper, I why won't your dash lights dim?
I put LEDs in my 92 D250 and they dim like a normal bulb.
- Stu Harmon
Re: LED equivalents for our filament bulbs [Re: feets] #1008394
06/09/11 05:47 PM
06/09/11 05:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Feets which superbright bulbs did you use? I'm looking at 194s but don't know whether to buy the 90*s or the 120*s.
Re: LED equivalents for our filament bulbs [Re: feets] #1008395
06/09/11 07:13 PM
06/09/11 07:13 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
No idea feets....when I touch the dimmer wheel they shut off if its not set to maximum. It doesn't bother me any. I am guessing because the LEDs have two positions....on and off...there is no limiting the juice to the actual diode...probably because mine are SMD LEDs and not the regular LEDs...
Re: LED equivalents for our filament bulbs [Re: Pyper70] #1008396
06/09/11 07:14 PM
06/09/11 07:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds to me like your dimmer switch is bad. The LEDs should work exactly like the standard bulbs as far as dimming with the switch. They are not just on or off.
Re: LED equivalents for our filament bulbs [Re: feets] #1008397
06/09/11 11:32 PM
06/09/11 11:32 PM
Houston, Tx
Houston, Tx
Good thread feets....
Troy
Re: LED equivalents for our filament bulbs [Re: stumpy] #1008398
06/10/11 11:35 AM
06/10/11 11:35 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used the 120s. The lights in my dash must reflect off the housing and through tiny little gaps between the gauges and the bezel.
I will caution you to NOT use the ultra-bright LEDs for the turn signals. The bright green light will blow you out of the truck when it flashes.
- Stu Harmon
Re: LED equivalents for our filament bulbs [Re: feets] #1008399
06/10/11 01:35 PM
06/10/11 01:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Thanks.
Re: LED equivalents for our filament bulbs [Re: stumpy] #1008400
06/10/11 02:16 PM
06/10/11 02:16 PM
toronto canada
69chargeryeehaa Offline
toronto canada
i played the led game....once....
spent something like $100 for tail light bulbs, put them in...had the flasher problem, then noticed that they intermittently worked, because the contacts on the bulb are oblong and don't really contact the socket correctly...then i waited until night time...all i could say is
looked like crap, did'nt fill the housing with proper light, just looked wrong on the car...took them back to the store, returned them and never looked back...after i got a refund i thought what was i thinking? spending $100 on led bulbs....it dawned on me that it was a 50-lifetimes worth of bulbs!!!
it was a total waste of time, the outcome was not worth it, and for that $ and aggravation i can't be bothered, plus to top it all off they look horrible in the housings...
Re: LED equivalents for our filament bulbs [Re: 69chargeryeehaa] #1008401
06/10/11 04:50 PM
06/10/11 04:50 PM
My hovercraft is full of eels
DaveKanofsky Offline
Here's a lengthy discussion on that topic...
http://www.dodgecharger.com/forum/index.php/topic,54734.0.html
Troy - I love them in my Daytona - you may have noticed them in my car at T'Ga in '09. I used the ledtronics.com taillights and superbrightleds.com for the dash lights.
The added benefit of LED tailights is they come on much faster when you apply the brake, alerting the person behind you that much sooner. As a test I put them in one side and turned on the 4 ways flasher, the LED's had come on and shut off before the regular bulbs had come on.
FWIW - I used the superbrightleds.com tailights in my Durango and Sebring but I think they could be better.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
