Any OOTB stealth head users here?
#1005316
06/02/11 04:26 PM
06/02/11 04:26 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
Curious to see what real world expriences with Iron heads then bolting on stealths... I plan on Doing some porting but Might just go stock for now In other words tell me your stealth ootb stories! ![](/ubbthreads/images/graemlins/smile.gif)
Re: Any OOTB stealth head users here?
[Re: PolyDart]
#1005319
06/02/11 04:44 PM
06/02/11 04:44 PM
Posts: 30,544 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
OOTB ports, but upgraded springs, retainers and locks. They're on a 512 with a solid roller cam, and 13.5:1 compression. Running 10.40s in a 3380lb Dart.
WHY diff springs, retainers and locks ?
[Re: dOc !]
#1005320
06/02/11 05:18 PM
06/02/11 05:18 PM
Posts: 876 Arizona
PolyDart
Arizona
Solid roller cam with .650 lift and 600lb open pressure.
[Re: PolyDart]
#1005322
06/02/11 05:26 PM
06/02/11 05:26 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
My brother is running them on a 10.5-1 383 with a voodoo 533 lift cam and they seem to work good. He doesnt have many miles on them but seem to make good power.
67' charger 499 RB
10.57 at 127
[Re: rebel]
#1005325
06/02/11 07:08 PM
06/02/11 07:08 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i swapped from iron,906 heads,to 440 source. both are pocket ported and milled to 78cc. picked up about 1 1/2 tenths. i did fit a thinner cometic gasket to pop up the comp,10.4-10.8,due to thermal efficioncy(spelling) with more tuning,some weight reduction and suspension work i am now around 6 tenths faster i am still using the supplied springs retainers etc - but i am running a purple 509 cam shifting at 6000 trapping at 6300.these cams are easy on the valvetrain. i am looking to go to a solid flat tappet next year when springs retainers and locks will be replaced Source qualify their retainers to 510 lift
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Thor500]
#1005327
06/02/11 08:14 PM
06/02/11 08:14 PM
shoebox
mckinney texas
Out of the box, on the car. Picked up 4/10ths low comp. 440 with a small mech cam. 11:50's in a 3600# car.
Very cool!!!
[Re: PolyDart]
#1005328
06/02/11 08:59 PM
06/02/11 08:59 PM
Posts: 2,119 sc
tjmarcus1
sc
why go to the expense of a solid roller cam and run an ootb head?
[Re: tjmarcus1]
#1005329
06/02/11 10:36 PM
06/02/11 10:36 PM
Posts: 2,141 junction city oregon
viperblue72
Why take the chance on breaking in a flat tappet these days? Plus the solid roller can't be beat for performance either. Plus I'm sure he will port the heads eventually.
[Re: viperblue72]
#1005330
06/03/11 08:21 AM
06/03/11 08:21 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
I changed springs,retainers,and locks on mine also.I run .588 solid with 4 speed.My machinist checked them back cut valves and cleaned them up a bit.Been 3 years street/and a few strip.No problems.Rocky
Chrysler Firepower
[Re: therocks]
#1005331
06/03/11 01:04 PM
06/03/11 01:04 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Has anyone ever had issues with the valve guides? A buddy of mine has these heads on a 383 with 1.6 rockers and a hyd. cam. His lift is right at .600" of lift. He used the springs that came with the heads with the upgraded retainers and locks. After 20 passes the valve guides were pounded down the valve stems.
I live with fear everyday but, sometimes she lets me race!
[Re: EchoSixMike]
#1005334
06/03/11 02:53 PM
06/03/11 02:53 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
ive never really seen tight guides though i ream them when i port them... out of the box they ream them from the port side up towards the valve top and sometimes there is a burr turned up above the guide which will restrict oil from getting in to lubricate teh valve/guide,,, ive told brandon about it and i believe he has fixed it with recent "batches" of heads
their retainers are std 7 degree retainers as used in the industry,, no problem there,, the locks are a hardened stamped 7 degree lock,, in most applications there wouldnt be an issue with a flat hyd cam or mild solid flat cams
jeff
[Re: moderncylinder]
#1005335
06/03/11 03:56 PM
06/03/11 03:56 PM
shoebox
mckinney texas
Fwiw my machinist has heard/seen some of the stealth 7deg locks Sink or"start" to pull through so we are going to change them During porting. I didnt know about the reamerin the guide. Good Thing to check ![](/ubbthreads/images/graemlins/smile.gif)
