Re: It's not looking good for testing this weekend.
[Re: joshking440]
#1004189
06/02/11 10:38 AM
06/02/11 10:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I am using the koffels B1 rocker. I believe people refer to them as a dove rocker for whatever reason.
Yes Mike, the hole I'm referring to is the feed hole to the shafts in the top of the head.
Josh do those shafts have the screw in plugs at each end... might want to open them up and clean the ID of them to see if you have any metal shavings in there from when they were made... could be plugging up some of the feed holes
[Re: joshking440]
#1004191
06/02/11 05:54 PM
06/02/11 05:54 PM
Posts: 4,699 On the parachute mount
n20mstr
DO THE SHAFTS HAVE A HOLE IN THEM TO OIL THE ROCKER? MAKE SURE THAT HOLE IS POINTING DOWN NOT UP....UP WOULD GIVE LITTLE OR NO OIL THROUGH THE ROCKER. ALSO MAKE SURE THE HOLES DRILLED IN THE ROCKERS TO OIL THE SPRING AND PUSHROD CUP ARE DRILLED ALL THE WAY THROUGH
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#1004192
06/04/11 04:20 PM
06/04/11 04:20 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
New Pushrods and Adjusters from Smith Bros are installed, I hope this was the issue all along, but if it wasnt, then the spray bar oiling set-up I installed will make sure we are getting all the oil we need up top. (Special Thanks to Bob George for the kit)
Assembled it all and set the valves this morning. It just got to hot out to change the oil, and start it up so I will do that tomorrow, or later tonight when the temp falls off
Also thanks to Pete and Chuck at Best Machine for answering all my dumb questions!!!
[Re: n20mstr]
#1004193
06/04/11 04:23 PM
06/04/11 04:23 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Bigger holes point down, smaller chamfered holes face the adjuster. I triple checked that when I put it back together. I also put moly paste on everything to help with the dry start
