Re: A833 stuck in gear ...breaking news... [Re: A990] #1002250
05/31/11 08:46 PM
05/31/11 08:46 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Did you put the side cover back together on the bench and test it? The 1-2 lever should be locked unless the 3-4 ball is exactly in the detent, and vice-versa.
Check that.
Your 1-2 and 3-4 sliders (the big round groove that the ends of the shift forks fit into) should be able to slide back and forth.
As far as lube, I would NOT use ATF, even thought some do. Get a 75w90 or 80w90 GL-4 (not GL-5) gear lube.
GL-4's are hard to find unless you look at Synthetics. Most all are GL-5 (formulated for rear-ends and not real brass-synchro compatable.
Redline makes a few, Pennsoil Synchromesh is good. Amsoil makes em too.
Re: A833 stuck in gear ...breaking news... [Re: Pacnorthcuda] #1002251
05/31/11 09:31 PM
05/31/11 09:31 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Check that.
That's exactly what happened. 3/4 locks out 1/2 and vice-versa.
Will check tomorrow (I got called in for an early shift, no progress today)
GL-4's are hard to find unless you look at Synthetics. Most all are GL-5 (formulated for rear-ends and not real brass-synchro compatible.
I appreciate this truth, I have a 05 SRT-4 and didn't understand why the transaxle gets away with ATF-4. I forgot about the brass synchros
Redline makes a few, Pennzoil Synchromesh is good. Amsoil makes em too.
What about Royal Purple? There's a dealer here in town
Re: A833 stuck in gear ...breaking news... [Re: A990] #1002252
05/31/11 10:16 PM
05/31/11 10:16 PM
Check that.
ATF type F,ATF4, Dextron-Mercon3 or any other atf is fine see the other post on ATF in a NP833 They came from the factory with ATF
