Re: Help with engine combo [Re: MR_P_BODY] #1001612
05/30/11 10:01 AM
05/30/11 10:01 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
following Gregs thoughts, If the the Stage V cast iron is legal it is an open chamber but can be milled to nearly a closed chamber (or use a quench step piston) and the ports have a bit higher roof and a better short turn so (in the right hands) with a 2.19" intake valve they probably have a bit more flow potential than a 915/906/452, mildly ported (se the tech archives) they flow a little better than OOTB edelbrocks, so going full tilt they could possibly flow in the 300+ range with less work/$$$ than a 40 yr old production casting.
Take some hints from the FAST guys, there's a few mid-high 11 cars running production manifolds, I don't know if they still police idle vaccuum but I'd go agressive on the lobe profiles and put the duration, centers and ICL where you need them to get the idle vac. A dual plane like the big indy will give you as much or more flow than you need (more potential than the RPM) and will naturally pull more idle vac than a single plane.
WIZE
In Car:
Re: Help with engine combo [Re: Streetwize] #1001613
05/30/11 01:57 PM
05/30/11 01:57 PM
Arkansas
mopartyson Offline OP
Arkansas
The heads must have production casting numbers. Does anyone know if the stage V have production casting numbers???? I can't find any info on this. I was thinking the indy dual plane was max wedge port???
Answered my question bout the indy intake. It is standard port. Still havent found anything on the stage V having casting numbers or not.
Re: Help with engine combo [Re: MR_P_BODY] #1001614
05/30/11 11:08 PM
05/30/11 11:08 PM
Arkansas
Arkansas
Ok here is what I have in mind.
440 block 40 over
Icon pistons 1.66 CH aprox 11.3
3.915 stroke
7.100 H beam rod
915 ported stainless valves 2.14 1.81
Comp cams XE285HL 285/297 545/545 110LSA
1.6 roller rockers
Performer rpm intake
850 cfm carb prob on E85
This would be legal in the class I will be racing.
Anybody care to guess a HP number???????
I would REALLY step up the compression, specially
with the wider LSA and the E-85
How much more compression ya think?? I just threw 11.3 out there because that's what the pistons are listed at with 78cc heads. Which is what a 915 should be but we know how that goes!! I'm thinking of a lil tighter squeeze, but can't say without knowing if the heads are going to be shaved much or not. I have not found a dome shelf piston and don't want to spend the $$$ on a custom set!! I'm hoping someone will chime in with more thoughts on the max wedge heads. I seen muscle motors has CNC ported 906 that flow 313 223 their site says the heads will support up to 650HP. Would that be my best option to make the most power? I would definitely like to get above 600 but don't know if its within reach.
Re: Help with engine combo [Re: mopartyson] #1001615
06/21/11 07:29 PM
06/21/11 07:29 PM
Arkansas
Arkansas
So I'm back with more ideas! Please give your input on this combo.
470 400 block 33 over
3.91 stroke
6.700 rod
Ross 14cc dome comp 13.5
518 max wedge heads
1.6 rockers
Cam 245/251 @50
570/576 110 lsa
Indy 400-2 4150 intake
Re: Help with engine combo [Re: mopartyson] #1001616
06/22/11 11:18 AM
06/22/11 11:18 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I would go with the comp pro magnum lifters, they are designed to act like a solid- giving you more rpm capability.
Too bad you're far from here, my brother and I were talking about selling his 63 max heads, they made 750 horse, ran low 9s-8? in a tube daytona.
The ports on them make my -1 ports look like 516s.
And, IIRC, they have 64 cc chambers
