Re: 94 Concorde alignment problem ??
[Re: FuryUs]
#1001457
05/28/11 05:13 PM
05/28/11 05:13 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Those are a pain it align.There is a special tool to keep the tie rod ends straight when you are adjusting and tighteing them down.It clamps over the tr end and keeps them straight.When my kid wrecked his Concord they had one end bound.Had to redo it.That and the ends adjust the wheel to center.Are the tires new? If they are try swapping them side to side and see if the pull follows the tires.Rocky
Chrysler Firepower
[Re: MO_PA]
#1001459
05/28/11 10:22 PM
05/28/11 10:22 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Are your strut bearings seized? They usually are on cars this old.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#1001460
05/28/11 11:11 PM
05/28/11 11:11 PM
Posts: 450 owensboro, ky
rallye73
owensboro, ky
Sounds like they got the toe front to back all out of wack. I had the same problem with my SRT-4 last time it was aligned. Did they give you a print out of the alignment? If so check the front and rear toe and make sure they are in spec. If the back is out it will cause a pull because the car is dog tracking. It will also cause the steering wheel to be off center. Ask me how I know.
[Re: wheelsup68dart]
#1001463
05/29/11 08:52 AM
05/29/11 08:52 AM
therocks
Niles , Ohio
I forgot the cradle bushings on them are known for going bad also.They fall apart and cause all kinds of problems.They are pricey also.Rocky
Chrysler Firepower
