My wheels get quite hot when I drive the Charger. I recently upgraded to discs up front (ebay kit manufactured by MBM - same as MP Brakes but with universal dual 8" booster and GM master).
How hard should it be to turn the wheels by hand? When I jack up the car I can spin the wheel just over once - and I have to use both of my hands! Is this considered normal or do I have excessive drag?
Check wheel bearing preload and it's fine - seems to be the brakes.
Will crack open a bleeder to see if wheels spin more freely then. Any other ideas?
