Has anybody tried Lunati Voodoo cam #60400 in a 318 truck? It is a 1987 2wd Ramcharger with 727 and 3.55 gears, 31 inch tires. Its a daily driver.
Brand Lunati
Manufacturer's Part Number 60400LK
Part Type Camshaft and Lifter Kits
Product Line Lunati Voodoo Cam and Lifter Kits
Summit Racing Part Number LUN-60400LK
UPC 090127605653
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,000-5,000
Intake Duration at 050 inch Lift 208
Exhaust Duration at 050 inch Lift 213
Duration at 050 inch Lift 208 int./213 exh.
Advertised Intake Duration 250
Advertised Exhaust Duration 256
Advertised Duration 250 int./256 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.454 in.
Valve Lift with Factory Rocker Arm Ratio 0.454 int./0.454 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
