Re: Timing
[Re: SD800]
#998451
05/23/11 11:50 PM
05/23/11 11:50 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
Where should we be at for timing?572 Mega Block14.3 compression114 octane Crank trigger at 36 degrees locked6AL box, to be replaced this week with a 7AL 3
I would never ask what timing to run on one of my motors based on someones elses timing light, especially using a MSD ignition box Use your timing light and start around 34 degrees total timing and the sneak up on what works the best at the track to get it to the fastest MPH you can get. Barometric pressure, altitude, actaul and density altitudes, humidity, batches of race gas and several other things can affect what the motor wants on any given day Are you chasing ET and MPH or wanting a consitent bracket motor? What brand and part number spark plug are you going to use to start with? The MSD 7AL3 boxes can move the timing a degree or two from a 7AL2, who knows about a 6AL box
